Question about Vehicle Parts & Accessories
Change battery and lost audio in 2002 yukon can't find the code to reset, what do I do. Follow the yukok book but still radio not working in Denali. .
  • Vehicle Part... Master
  • 4,861 Answers
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Posted on Oct 01, 2009
How to reset the change oil light on 2002 yukon Denali
this is in the operators guide, lost that?
Jul 15, 2014 | 2003 GMC Yukon XL
We have a 2003 yukon denali xl. we have a signal saying battery not charging. we replaced battery and alternator. still won't charge. truck goes completely dead. no lights, radio anything. what el
I'll try to help, everytime something gets replaced on these yukons, that circuit needs to be RESET ! Is there a reset button, on your steering wheel, to reset a variety of functions ? , check owners manual, or call your dealer for better advise
Feb 15, 2013 | 2007 GMC Yukon XL Denali
HOW DO I RESET THE CHANGE OIL LIGHT ONCE THE OIL
look in the manual......turn the ignition to the on position not starting it of course and then pump the gas petal 5 times then the light will blink a few times turn off then back on...problem solved
Jan 30, 2010 | 2002 GMC Yukon Denali
Volume in 2003 yukon denali quit working on radio,
check your manuals guide book on reprogramming the radio and where would you find the fuse for the radio first check the fuse then reprogram if this information has been helpful please let us know good kuck
Jul 28, 2009 | 2006 GMC Sierra Denali
2005 yukon denali, a/c worked fine until battery died
Get the climate control computer relaced or reprogrammed. There is a good chance that when your vehicle was jump started it fried the climate system.
Jul 05, 2009 | 2004 GMC Sierra
Need color codes for radio in 2002 gmc yukon denali
2002 GMC Yukon Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
May 23, 2009 | 2002 GMC Yukon Denali
I have a 2002 Yukon Denali. The other day I went
check for loose battery connection. or maybe a cable going bad. they can corrode inside and the copper wire will turn green
Mar 11, 2009 | 2002 GMC Yukon Denali
I have a 2006 Yukon xl Denali with the Bose radio/ Navigation and separate 6 disc cd changer. The am/fm radio works fine, but when using XM, the channels get stuck and have to be turned manually.
generally it would just need to be reset... unhook the battery for about ten minutes and hook it back up. make sure you have the unlock code for the radio FIRST and you know how to enter it.
Robert
Feb 17, 2009 | 2006 GMC Yukon Denali
Yukon Denali Fuel Trim bank One and Two running too lean?
Could also be fuel filter, pressure, vacuum leak, etc. Check these two articles out, they should help too - http://www.obd-codes.com/p0171 and http://www.obd-codes.com/p0174
Dec 21, 2008 | 2002 GMC Yukon Denali
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
