I have changed my rear projection lamp and now the picture is green can you tell me what is causing this please.
    Scholar:
  • 146 Answers
It sounds like your light engine is defective. My Projection LCD had this happen and it started with a growing blue haze, others experienced a yellow haze, I suspect yours is manifesting with a green green haze.
It is a very expensive fix, depending on the age of your set, you may find it cheaper to replace it with something new, because a light engine itself costs nearly $2000 and another few hundred to install and align, not something a do-it-yourselfer is able to do
Posted on Oct 01, 2009
  • 5,138 Answers
Light Engine or Color wheel, if it is color wheel you will hear a whinning noise.
Green light blinks and eventually turns solid green but only black screen no picture
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then its time to change lamp.
Buy Sony original lamp for good picture in tv.
Aug 27, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green Power light blinks for about 60 secs, then
YES New lamp needed the model number will be on old one does not take long to change if still got hand book shows how change
Nov 07, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
michtech
Feb 18, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Intermittant lamp cycling
could be lamp or lamp driver the only way to tell is to replac on at a time.
Aug 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture
If the red light stays steady, and the green light blinks 9 times then repeats, it is most likely the lamp #23311083A about $200. Otherwise, if a cooling fan is not working, it could possibly cause a shutdown problem. You can't always tell a bulb is bad by looking at it. Another possibility is the lamp ballast, but I would try a new bulb first.
Feb 10, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Televison & Video Logo
319 people viewed this question
Top Televison & Video Experts
Electro Med Services...
