Question about Hitachi 50UX52B/53K 50" Rear Projection Television
Black horiz. lines appear in the picture when the set is on after a few moments. big john
Tv was 12 years old, I retired it and bought a new one.
Posted on Oct 02, 2009
There's a very narrow line (white) appears at the very top of the screen when the picture scene is mostly black. A verticle adjustment should fix it but where is it?? RCA F36TF720
it may be an electrolytic cap problem as most newer sets are controlled by an I.C. chip for horiz and vert timing/size/linerity
Nov 02, 2009 | RCA F36TF720 36" TV
Colors dont line up, black square,in middle
with no model or make, all i can suggest is that one of the convergence amplifiers is acting up(usually there are two used in most rear projection sets) they may have to be replace at the same time to avoid doing the same thing later on. look for a heavy metal heat dissipator tha is where they usually mount.
Aug 03, 2009 | Televison & Video
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Wavy White and Grey lines then nothing
The Flyback transformer needs to be replaced on the Deflection Board. It has the big red wire coming out of it going to the picture tube. Becareful with that. Some of them hold a nasty charge waiting to bite someone. Wont kill ya, but it hurts.
Feb 08, 2009 | Toshiba 32AF43 32" TV
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
Picture looks like it is stretched too tall & wide
Probable regulator circuit damage = research at......................
www.HitachiServiceUSA.com ...............T.
Nov 09, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Big black screen in picture
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
Sep 19, 2007 | Televison & Video
Tv picture
Your closed captions are on and set to TEXT. Go into the menu, turn off the closed captions and the black box will vanish.
May 22, 2007 | Zenith SY2768S TV
Picture getting small blacking out
Yes you sound like pincushin is failing on you. Soon it will knock out horiz. output caps and Diodes. Needs repair soon.
Apr 25, 2007 | RCA F35673MB 35" TV
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
