My toshiba tv goes blank after few seconds then comes back on
  • 1 more comment
  • jiwans Oct 01, 2009
    my toshiba tv model 36zt29b goes blank with no sound for few seconds then comes back on with picture and sound
    hi my tv model is 36zt29b projection , i did try with different connection but that problem still there
  • jiwans Oct 05, 2009
    hi ,my toshiba tv 36zt29b model goes blank for few seconds then comes back on
  • 19,396 Answers
Hi.
If the light is shutting down, and you get dark screen for few seconds, then problem can be PSU, lamp or CRTs power board, or a digital board fault.
The board that supplies power to lamp must be tested. If that is testing ok, then the PSU higher voltage connector must be tested.
If the TV remains with a blank screen with light, then it is a faulty digital board, or depending on the model a problem related to optical group fault.
In both situations this is not a common fault, and testing and troubleshooting may be quite complex. Unless you are a technician, you should call the phone number listed on the owners manual to get support. If you are a technician in this case you may still need to follow the service manual to diagnose the fault.
Regards.
Posted on Oct 05, 2009
  • 448 Answers
Try connecting different video sources to the TV such as a DVD player or a cable box using different connection such as HDMI or component cable to isolate the issue.
If the issue is occurring with any particular connection type (such as HDMI or component) then you may contact the manufacturer of the TV to check for the availability of any System Software update to address this issue.
Good luck!!!!!!!!!!!!!
Posted on Oct 01, 2009
    President:
  • 1,884 Answers
It seems that the display IC is playing foul. Check and replace.
  • 250 Answers
It sounds like the projection lamp is getting ready to burn out, or there is a problem with the lamp driver circuitry. Something could be overheating. Make sure the ventilation ports are clean and clear and that the television has enough room for ventilation.
4 Suggested Answers
  • 185 Answers
SOURCE: picture goes blank for few
what brand and model?
Posted on Oct 08, 2008
welcomejee
  • 10594 Answers
SOURCE: when watching tv on any mode...after a few seconds
Time to replace Lamp in TV.
Existing lamp getting weak and causing that problem, replace lamp and TV will be fixed.
Buy Sony original lamp for TV safety and lamp replacement procedure is written in user manual.
Thanks.
Posted on Jan 17, 2010
ladywinn
  • 5138 Answers
SOURCE: What is wrong with my tv when I turn it on the
Deflection board ,you can ship it to either PTS or UED for rebuilt board.
PTS 1-800-844-7871
UED 1-800-648-6657
Posted on Jul 02, 2011
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Screen goes blank, audio still works
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
