Printer says, one of the cattriges is not
Printer says, "one of the cattriges is not installed properly" despite installing it properly several times. then it goes on to say "the following ink cant be recognized - color", despite it being an original recommended canon cattrige
  • 855 Answers
Check the cartridge the circuit board area may be damaged.
Posted on Oct 01, 2009
How to fix Fatal Error on printer
What operating system? HP has had problems in the past with some installs not working properly. Check the install disk for a program called SCRUB.exe. Unplug the USB cable from the printer, run SCRUB and this clears all traces of printer out of registry. Then rerun the install, making sure that you run the install as an administrator and that you disable any virus protection and firwalls while performing the install. Also make sure you follow the instructions about when to attach the USB cable as starting install with the USB attached will cause problems.
Sep 13, 2014 | HP Photosmart Premium C309g All-in-one...
I've loaded my hp photosmart D5063 printer, but when I click on print there's printer error.
It's either your cartridge is wrongly installed or check your cable are well connected
Or use the printer manual to install properly
Or better still use another system
Aug 09, 2014 | HP EPPSD5063PHOTOTRAYAS PhotoSmart D5063...
I changed the ribbon to the monochrome R3012, but the printer has the NO RIBBON light on and it won't recognize it. I set the printing references to that ribbon style, the ribbon is not torn, I have made...
You may have installed ribbon incorrectly.
Align the gears of ribbon spindle with gears on printer and second important thing is that ribbon should come from up not from down.
Mar 13, 2011 | Evolis PEBBLE 4 Led Card Printer
Epson C63 will not print despite having changed all the inks. It tries but the paper is blank
I think there are 2 causes epson c 63 printer not print problem.
First one is: Your ink cartrige are not install properly.
Solution: Try to install ink cartrige properly, in this time please clean ink cartrige chip as well as connector.
Secoundly: printer main board problem. Print data does not pass through main board.
Solution: Please replace new one.
I think you will relive from the problem.
Thank yoou.
Feb 28, 2011 | Epson Stylus C63 InkJet Printer
Why is the yellow ink is not coming through on my canon inkjet mp780 - despite having cleaned, deep cleaned and re aligned the nozzles several times?
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon Office Equipment & Supplies
My HP LaserJet 1320 will only print a single copy of a document despite filling in the 'number of copies required'.
make sure the toner is proper and it is not empty just re-install the printer driver aslo.
Jan 12, 2010 | HP LaserJet 1320 Printer
Colour printing
Is by any chance a third party cartridge?
Jan 13, 2008 | Office Equipment & Supplies
Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
70 people viewed this question
k24674
