Question about Braun 360° Complete 8985 Electric Shaver
Suddenly,the trimmer blade of my braun 8985 shaver has started literally plucking my hair..i don't know wht the problem is
    Novelist:
  • 124 Answers
If you've used the shaver for a very long time, it could be that the trimmer part has worn out. You can buy a replacement body for your 8985 that includes the trimmer, from shaveroutlet.com. Replacement is not very difficult (not soldering involved). You pull off the bottom plug socket, take off the sides, unscrew 4 torx screws on the body, and the shaver comes apart. Good luck!
Posted on Oct 22, 2009
Hi, I have a Braun series 3 shaver and sometimes
blades are blunt and the hair gets stuck between the clipper blade and the fixed blade
have them sharpened or replace with new one s
Nov 10, 2017 | Braun 380 Electric Shaver
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
Sideburn trimmer does not cut anymore but still makes noise. trimmer blade does not move.
It is pretty common for the trimmer to get jammed up with hair particles and skin oils which can prevent the blade from moving.
Try running the blades of the trimmer in a shallow dish of rubbing alcohol. Then clean the blades vigorously with an old toothbrush or similar. If the blades still does not move try using the tip of a small flat screwdriver or similar object to push and advance the moveable blade. Repeat running in alcohol and brush clean
If this doesnt work, you will probably need a new trimmer
Apr 15, 2010 | Braun 360° Complete 8985 Electric Shaver
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
Where can i take my braun shaver for service? needs a foil/blade replacement
you can buy replacement cutter blocks and foils at walmart...about 50 bucks.
Mar 28, 2009 | Braun 360° Complete 8985 Electric Shaver
The blades on my Braun complete 8975 are not sharp anymore.
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 360° Complete 8985 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
444 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
