Question about Pioneer Audio Players & Recorders
Just simply no sound from it at all. Rear speakers went first then complete failure. Everything else o.k.
Took it to the local repair centre !!!!!! before we made the problem worse. Waiting for the outcome.
Posted on Oct 02, 2009
How to replace rear door speakers for 1997 GMC jimmy
I think your GMC have in-door rear speakers.!!
  • Look for screws in door panel or around the speaker vents.
  • If you are sure that the speaker cant be removed without opening the door panel then read this below.
  • Mostly seen near areas like door lever(inside), power window switch set, bottom and each sides of the whole panel.
  • If its manual window, then look for a circle clip in between the winding window lever and the door panel. Plunge screw driver between them a make a gap then look.
  • Assure that all clips or screws which obstacles the removal of the panel.
  • Simply pull the panel from sides towards you
  • If its completely open, then locate the speaker and unscrew it.
  • Check the connection wires for quality
  • Mostly its good to scratch the leads of the wire to remove copper oxide layer
  • Take the new speaker, check the holes on the door matching the speaker's
  • If needed, drill hole for screw and be sure that the new speaker is not more than 15cm diameter.
  • Connect the leads, fix the speakers.
  • Check the sound clarity with your car audio on.
  • If everything is perfect.. go on , fix the door panels
  • Mainly sure with the side clips of the panel, do not bent or break them.
  • Check for any balance parts or screws.
  • Screw everything back as normal.
  • You just installed a new speaker....
  • pls rate it!!
Sep 23, 2011 | 1997 GMC Jimmy
I have had my Marantz Sr5000 for some time now and I just noticed the rear speakers have stopped working. Everything else seems to be working fine. When I run the test tone I get a tone from everything but...
First of all if you have not made any connection changes in the system prior to loosing the sound try these steps.
Go into the system menu and in speaker configuration see if somebody has given the rear ( surround ) speakers as none. If not just exchange the front and back speakers to confirm if its a speaker failure . If not you will need professional help to fix a damaged surround amplifier.
Mar 08, 2011 | Marantz SR-5000
2007 avalanche rear speakers have no sound output. I don't believe they both could blow at the same time.... the rear radio is not on so it isn't that muting it. Is there some issue where they may mute...
I too have no sound from rear speakers...I bought speakers thinking they were simply not there. Went to install them and found that there all of a sudden was sound there. Put the rear door panel back on and it still worked until the next day. No sound from either side on rear again. I read somewhere that a seatbelt could be damaging a wiring harness causing it so I took off the panels covering the seat belts and found no way that the harness could be damaged from the belt. Weird how they worked momentarily when i had the pass rear door panel off though.
Aug 27, 2010 | Car Audio & Video
Mitsubishi WS-65907 65 in. Rear Projection Television; No Sound from internal speakers. I don't believe external speaker will work either but I have no way to test. TV was move from one home to another....
first you need the original remote to do this, with the set on use the remote to enter the following (menu) 8,2,7,0 this will bring up the options menu the first thing in this list is "Inital" and should already be highlighted then simply press enter on the remote, this should reset the tv
Dec 22, 2009 | Mitsubishi WS-65907 65" Rear Projection...
LG VX8700 - No sound coming from speaker
Sounds just like the problem I had. I took the phone apart and removed the internal speaker. Tried the contacts with another speaker from another phone...and it worked.This leads me to believe that the internal speaker has failed. I am now on the hunt to get a replacement speaker.
Jul 12, 2009 | Lands Phones
2001 Buick Regal, Rear speakers not working properly
Well the voice coils in the speakers may be fried, or on their way out. Has anyone been simply turning it up too loud, or too bassy, or at obscene levels.
May 27, 2009 | 2001 Buick Regal
My back speaker doesn´t work,, everything is
It sounds like it's your radio if it's the OEM. To make it somple the factory radio had there separate amp muilt in each chanel so if one speaker went bad the others woudl still play. There is no quick fix other then haveing it replaced or if have it repaired.Good luck and just dubble check all the connections
Apr 08, 2009 | 2004 Dodge Durango
Right Front and rear speaker do not work proberly.
I ran into the same issue with an AVR 7000 after it had been shipped to me. I took the cover of and found that the left and right amplifiers have a separate power plug into them. when I plugged to "bad" side back in everything worked great.
Dec 30, 2008 | Harman Kardon AVR 7000
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
21 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
