Question about Nokia N95 Cellular Phone
Wont switch on
I can plug phone in with charger , the screen goes white says NOKIA bleeps and shows [top rt hd corner] charging
then when charging is finished it bleeps but wont turn on have tried to hold switch on for long periods but still nothing when i remove chager lead it bleeps agin and for a split second you see the orange symbol thenits off and blank .
Ive tried a new battery also the phone is 8 miths old
  • oxo27 Dec 20, 2007
    ok thanks so far but it still wont start up the nokia on the screen stay a little longer but still does not vibrate or switch on
    any other help would be great thanks
  • Jinxilla Feb 06, 2008
    Yep, same problem. I tried all the button pushing suggested, but no go.
    Someone said it needs to be flashed? Who can do this and how much?
  • 1,944 Answers
Did you try to reset the phone.
Normal Reset (*#7780#) : Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
Hard reset
Press Call + 3 + * simultaneously during the bootup phase, forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Posted on Dec 20, 2007
  • Damen Wong
    Damen Wong Dec 20, 2007
    The phone requires a flash of the firmware.
My phone stopped charging and it wont work where the charger part is.
get a new charger..if it dont work..your plug on your cell needs repair
Jan 08, 2014 | Nokia Lumia 820
The phone does not switch on.. when I press the not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times...
hi there!
try changing batteries. or try turning it on while charging, if theres no problem when its directly plugged in with the charger, the battery may be dead (especially if its more than a year old and is frenquently used for calls and internet). if its having the error while still plugged in directly with the charger, a local technician is the best here.
Apr 08, 2011 | Nokia X3 Cell Phone
I have one of the pink Nokia BL-4B phones which swivels round, and a while back it started acting up and freezing on me. I switched it off, and when i tried to switch it back on again it just showed a...
nokia BL-4B is the battery model i think you,ll find its a 7373 or a 7370, by the sounds of it you have a software problem you may need to get it reflashed at a mobile service centre.
Dec 21, 2010 | Nokia Cell Phones
Hii My Nokia 5130 Express Music phone doesnt start up. It shows "test mode" on plugging the charger. Even otherwise, on starting the phone the Nokia logo appears ten the screen goes white and switches...
please format your phone using first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
Oct 20, 2010 | Cell Phones
My nokia 6760 wont power up even when on charge i had it plugged into the computer last night and it just stopped working
My 6760 beeps loudly and shows a bright white screen with the battery in the corner when i connect it to my wall charger.
Are you plugging it into the right spot? There's a cover over the hole where you plug the wall charger into.
You might have a problem with the connections to the battery/phone. Take the battery out and have a look at the connections.
Any damage to the battery (water, dropped) it may kill it. Try buying a new battery and test it before you walk away from the store. If the second battery works, check your cable and buy a new cable.
Hope this helps
Sep 02, 2010 | Nokia 6760 Cell Phone
Hi! I have a problem with my Nokia 7370 : the screen is blank and nothing is happening. I tried switching it off, then on again, but no luck, I have nothing but a blank screen. Even when I plug the battery...
can u hear any sound like nokia tune which comes when u turn on your mobile? It could be because your display is damaged or not working so please visit nokia showroom and they will help you.
There can be several things which can be reason for blank screen like:
1. Your display is not working
2. Battery of mobile is not working.
3. May your mobile is not charged and charger which you are using is not working. Try charging with some other charger of nokia same pin.
4. It could be software issue. Please update software in your mobile.
60% it could be a display issue.
Jul 21, 2010 | Nokia 7370 Cellular Phone
Pantech C810/Duo Power Problem
Aug 31, 2009 | Pantech Duo Smartphone
N96 wont turn on, when charged the naviwheel is on and screen...
Try a different battery on your phone and try this battery elsewhere to ruleout a bad battery (yours). Your battery could be dead.
Aug 09, 2009 | Nokia N96 Cell Phone
NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
Nokia problem
If I am correct, the 'Ice Wire' has snapped. This causes the phone to act very strange or freeze on the opening screen.
This means you must take the shop that sold it to you or your can contact the creators of the phone. In your case, the phone s Nokia so you would contact Nokia.
Hope this helped,
Mar 09, 2008 | Nokia N70 Cellular Phone
Nokia N95 Cellular Phone Logo
218 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
