Question about Goodman Heating & Cooling
Have a goodman model#capf3642c6aa;need to know how to relite-help& thanks
2 Suggested Answers
keith91gmc
  • 52 Answers
SOURCE: I also have a Goodman CAPF3642C6AA and need to
the arrow goes towards the blower motor
Posted on Dec 19, 2009
Please could you help me & if so I would like to know if there is a code to set my universal controls to a GOODMANS GDB9 set top box. Yours sincerely Keith Hunn
Good day!
I need to know the universal remote model?
device type you'd like to set?
and manufacturer of that device type?
or you can try this universal remote code finder.
http://universalremote.manualsonline.com/
thank you and don't forget to rate my answer..
Jun 08, 2011 | Televison & Video
I have a Goodman GMS9 Furnace that ignites and runs perfect for about 5minutes and then I will here a woosh of air and the flame goes out and inducer motor stops for about 3 seconds, then it re-lites and...
This is a common problem with this brand and can even often fool HVAC contractors! There is a control module/circuit board inside the furnace that needs to be replaced for proper operation. The circuit board controls multiple functions and switches and relays inside the equipment and it begins developing a mind of it's own and starts turning certain things on and off at improper sequences. Most of Goodmans furnaces come with a 10 year parts warranty, so try exhausting that resource first before buying one.
Hope this helps James
Apr 06, 2011 | Goodman GMS90703BXA Heater
GAS DRYER TUMBLING ,BUT NO HEAT.
Most of the later model dryers have electric ignitors, sounds like you have a ignitior, that is burnt out.
Take the brand, model and serial numbers to a appliance parts store to get the part.
If this has been helpful, please rate the new guy :)
If I can help you any more, just give me a shout.
Sincerely,
Paul Gibson
Apr 05, 2010 | Goodman GMS90703BXA Heater
Goodman furnace intermittently fails to ignite. Will flash code for ignition failure. Always relites when reset. Tends to happen much more often after hours on non use. During weekdays when the thermostat...
I do not have the figures with me at this time. If the ignitor is slightly out of proper resistance range, it may not be getting hot enough the first time it tries after being idle for a while. I would need my chart from work and the model of the unit, but have your last tech check that. They can call for the proper resistance to the Goodman tech line at 888-593-9988. And, the pressures should be 11-13" w.c. input and 10" out to the manifold when valve is open. If the input pressure is higher than 13, the valve diaphram could intermittently lock up.
Jan 03, 2010 | Goodman Furnace Draft Inducer Blower ...
I have a goodman gmp100-4 gas furnace and the gas comes on but shuts off in around 30 seconds, then tries again and the same thing... can i get some help please?
On the last gas venturi tube there should be a flame sensor located in the flame to prove it exsists, if its coroded the spark can,t jump back thru the moisture molecues in the gas to prove it has a flame to tell the circuit board to keep the gas comming. Just reomve the flame snsor and sand itand replace itback. T. Y. V. M.!
Dec 01, 2009 | Goodman GMS90703BXA Heater
Do you know how I can get a Goodman Ht pmp Manual
this manual willl not help your system perform better , have a qualified tech check your sub-cooling. temp diff, and match your piston with your coil. many goodman systems may say they are 3 or 4 ton but are half a ton smaller than advertised at the compressor. a three ton system will have a two and a half ton compressor
Oct 01, 2009 | Goodman Heating & Cooling
GOODMAN CPLT36-1 WITH HONEYWELL VISION PRO STAT 8000
what is the trans former voltage needs to be 26- 28 v. and is the board fused max 3-5 amp fuse I know it is on of the two check all of your wiring. good luck Tom
Jul 11, 2009 | Heating & Cooling
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Coil piston
If you purchased it as a package the right piston may already be installed in the indoor Evaporator coil. When shipped the extra piston if needed is packaged with the outdoor section condensing unit.
May 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
214 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
