Question about Kenmore HE2 Plus Front Load Washer
No power when plugged in, power at wall but the controls will not go on
  • 11,896 Answers
Either a fuse is bad or power supply is bad which is common. you can check power supply power with voltmeter and look at fuse
Posted on Oct 01, 2009
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
Oct 07, 2014 | Sunbeam Electric Blanket - queen
Cant find the flag tag to reset my electric blanket control
Oct 05, 2014 | Sunbeam Electric Blanket - queen
The light wont even turn on when i try to turn mine on, it hasnt been turned on in a while so i yeh , does anyone knoe what i should do ??
  1. Make sure you are using a licensed AC Adapter (the system's power cord). The name Nintendo should be molded into the actual AC Adapter unit. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly. Also ensure all accessories connected to your system are licensed as well. (Expansion Pak, Controllers, Rumble Pak and Controller Pak.)
  2. Make sure you are not using any game enhancing devices. Such devices are unlicensed and are not recommended by Nintendo, as they may not let your system function properly.
  3. Firmly plug the AC Adapter into the AC Power Supply port on the back of the Control Deck and firmly plug the AC Adapter into the wall outlet.
  4. Make sure your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
  5. Slide the Power Switch on the Control Deck to the ON position.
  6. If it still does not work, you'll need to RESET the AC Adapter. To do this, remove all the accessories (including the Game Pak and all controllers) from the deck. Unplug the power supply from the wall outlet for at least 30 seconds, then plug it back in. If your system works without the Game Pak and controllers plugged in, there may be something defective with either the Game Pak or one of the accessories. Turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time to see if you can figure out which accessory may be in need of repair.
If these steps do not resolve the symptoms you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Dec 15, 2010 | Nintendo 64 Console
I can't seem to get my nintendo 64 connected. I've tried 3 different tvs and I got it to work for a short period of time today but it was not the game I wanted to play. After I turned the game off, I...
Nintendo 64 Power Problems
Nov 27, 2010 | Nintendo 64 Console
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Sep 18, 2010 | Sunbeam Vacuums
My thermostat has no power. the wires to it has no power. The fuses on the heater chip board are okay. What else can I do? Where can I locate the transformer to the A/C/Heater?
in the control box to your furnace or air handler, there should be a transformer near by.be careful though, it has high voltage going to it though.just follow the high volt wires, the large ones,from the wall plug to the machine, into the control box to the transformer or the fuse chip board.the big black wire will go to terminal L1 at the board and the white wire will go to nuetral at the board.unplug your wall cord first so you won't get shocked. it is hard to see into the control box and board connections.also, plug a light or lamp into he wall socket to see if you have 110volts to the plug.
do that for a split system.an airhandler wont have a wall socket.it will have a disconnect box with fuses in it.it is also 240volts so be carefull.
Dec 29, 2008 | Amana Heating & Cooling
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Aug 16, 2008 | Dryers
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Kenmore HE2 Plus Front Load Washer Logo
352 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
