Question about Refrigerators
WATER LEAKING ON FLOOR BLOCKED AT BACK INSIDE OF FRIDGE ALSO ICING UP WHERE BLOCKED
  • 11,896 Answers
The drain is most likely plugged or frozen. I suggest defrosting the entire unit and use heat gun or hair dryer on drain tube. Make sure bottom of drain tube is not plugged and that water is dripping into evaporator tray attached to top of compressor. There should be some water in here. If completely dry, then drain hose is plugged. Coathanger helps and heat.
Posted on Oct 01, 2009
WATER LINE BROKE ON INSIDE WHERE IT COMES IN FROM THE BACK. THEN LEAKED ALL IN FREEZER & THEN ULTIMATELY CAUSING TO FREEZE UP
Can you post a photo of what you see in the freezer? Are you sure because this may be a leaking water control valve causing water to flow over the ice maker and then down to the floor of the freezer. It also could be a defrost drain blocked with gunk and ice. Leaking Refrigerators. What is the model number of your fridge? APPLIANCE 911
Dec 06, 2015 | Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Water leak front left corner of freezer.
Your defrost drain line in the freezer is frozen closed.
You must turn off the fridge.
Remove the visible ice.
Use a hair dryer at the drain opening in the lower back of the freezer to melt the drain line ice.
Mar 11, 2009 | Electrolux Refrigerators
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Jul 08, 2008 | Refrigerators
Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Jan 21, 2008 | Jenn-Air JCD2295HES Side by Side...
Defroster leaks
is the drain hole at the inside/back of the fridge blocked? check that you do not push foodstuffs too far back against the wall, and is there excess condensation from veg etc?
May 29, 2007 | GE PTS22SCRBS Top Freezer Refrigerator...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
