Question about Acer Computers & Internet
How to connect travelmate 2420 to tv? through its vga output to a TV with an S-video input
    Guru:
  • 355 Answers
From s-video
Posted on Oct 01, 2009
2 Suggested Answers
bschilz
  • 2049 Answers
SOURCE: how to connect vga output to 3 rca tv input ?
Do an online search for a Video cable - Male 15 pin HD D-Sub (HD-15) to M RCA
Posted on Dec 08, 2009
My laptop doesn't have a HDMI port so I have to connect with two cables...I think ones VGA and the other is audio. This goes into the back of my old smaller tv...which is ok but I'd like to route the
Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
Jan 15, 2015 | Computers & Internet
Tip
How To Connect Flat Panel TV to Computer
Hello <br /> First identify your TV's input connections. Most TVs these days have three basic types of inputs. You have your coaxial cable input, the same as your cable box or satellite, an RCA composite input (the yellow, red and white inputs) and an S-video connector. Newer televisions might have Component Video, DVI, VGA or HDMI inputs but the ones listed above are more common. <br /> Identify your computer's outputs. These days computer manufacturers are adding TV compatible outputs on their products so it's easy to have a pc to tv connection when you hook it up. The S-video in particular seems to be popping up on more and more computers, so a PC to TV S video connector might be what you need. You can shop for S-video cables all over the place online. Mostly you will find the usual VGA output that the regular monitor hooks up to (see more later on VGA cables). The newer multimedia computers will probably have all high definition outputs that connect directly to your HDTV, but for now we will deal with what most people have for both computers and televisions. <br /> Find the appropriate adapter for your connections. You may need to get a computer to TV cable so you can hook up your computer to the TV. If you have an HDTV, you may need a VGA to component cable. This VGA to component cable connects your computer to a HDTV and acts as a converter. (And that computer could be either a Mac or a PC.) <br /> A PC to tv connector has a VGA adapter on one end and (usually) a selection of connectors on the other (S-video, RCA composite and Component). The good thing about these is that you can take it from TV to TV and you'll be able to hook up computer to TV for all of them. I highly recommend a wireless adapter. It costs a bit more but wireless is worth not having a big cable mess and not keeping your computer near your TV. <br /> or you can get help from this video <br /><br /><img src="utube.png" /><b><i> You-Tube video "ZCN-nN1orYE" placeholder (do not delete) </i></b><img src="utube.png" /><br /><br />Hope this helps, if so do rate the Tip.<br />
on Jan 25, 2011 | Televison & Video
Connect acer to tv
Assuming your TV has a VGA input socket, plug the VGA lead in, select Computer input on your TV and power up your laptop.
Mar 20, 2014 | Acer TravelMate 6293-6727 (LX.TQP0Z.C54)...
Can i hook my lap top up to this tv to get netflix? How?
Hello
This model CRT tv cannot be connected directly to lap top. Laptop has VGA output and there is no VGA input to this TV. Tv has only AV sockets to connect in. You must have a VGA to Audio Video converter to be used in between TV and Laptop. This device can be bought from electronc shops. It will have a VGA input, and audio video output. You have to connect your laptop to this device using a VGA to VGA connecter, and from this devices' output, you will get audio video output, which can be connected to TV and select the TVs' input to AV. OK.
Jun 03, 2011 | JVC AV-27F702 27" TV
How i can connect the tv as my computer moniter
Does your TV have a "VGA" input? If so, then connect the VGA-output from your computer's video-card to that VGA-input.
Does your TV have a "DVI" input? If so, then connect the DVI-output from your computer's video-card to that DVI-input.
Does your TV have a "S-Video" input? If so, then connect the S-VIdeo-output from your computer's video-card to that S-Video-input.
Note that only _SOME_ video-cards have DVI output or S-Video output. Check your video-card.
Dec 01, 2010 | Computers & Internet
How to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
How to connect vga output to 3 rca tv input ?acer travelmate 2420 to panasonic tv
Dec 08, 2009 | Acer Computers & Internet
I am trying to connect my PC to my TV. I have a Sharp HDTV and my PC is a Toshiba with windows XP. I have a componert video cable which is connected to the TV and PC. I have used Fn and F5 didn't work....
what model of TV was it please,
Does your computer have tv out video card installed?
For video to tv you will need a vga to tv converter,this is an external device and will work on the computers vga output straight into a vga input and give you 1 x vga out,1 x rca out, 1 x s/video out,comes supplied all prebuilt with onboard graphics solution. no extra power required runs straight of vga output.
Once the computers video output is established then set the TV up to tune into the converters output signal.
HD TV can be set up to run thru rca and components and if model is late enough shuld come equip with serial vga input for computers.Other than that HDMI seems to be the better quality of picture over rca component.Cost verses dollar really and function.
Cheap fix VGA to TV CONVERTER
Expensive Fix HDMI to HDMI
(it is posible to hdmi over cat5e)
NO COMPARISON FOR QUALITY.
Jul 10, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
