Question about Consew 226R-1
After sitting unused & neglected for a couple of years my consew 226 has the button you press for adjusting the stitch length seems to have seized completely,It still sews O.K. but is set on a very fine stitch length & oil & WD40 have failed to unstick it so far. Can anyone offer any suggestions? Thanks Dave
  • 208 Answers
It may take a lot of hand strength. If not, try heating with a hairdryer to loosen.
Posted on Oct 01, 2009
Testimonial: " Thanks for the advice,I'll try it SL loon "
My sewing machine only feeds material backward an not frontwards
Posted on Jul 03, 2010
Why is my stitch length disengaging the clutch when I try to adjust it?
Remove the belt. Check that the bobbin case is installed correctly. Hold the button down while turning the wheel. Also check the lock screw on the shaft. It can get loose, or too tight.
Jul 03, 2014 | Consew 226R-1
Part number for the stitch length adjustment knob
This machine doesn't use a knob, there's a button to push which engages the stitch regulator under the machine.
Jan 22, 2014 | Consew 255RB-3 Mechanical Sewing Machine
New Consew 146 rb 1-a Stitch length dial is set at
I would suggest taking the machine in to be adjusted and make sure they can work on that model machine, and if they can, then the same day you get it back, sew on it to make sure the problem is fixed.
Oct 23, 2013 | Consew 7360R-1 Mechanical Sewing Machine
I have just aquired a consew 288r-1(no manual) How do I adjust the stitch length, and tensions?
The stitch length adjustment is the same as some other Consew post models, located on the manual advance wheel
See :
http://consew.marginspluslive.com/images/products/instruction%20manuals/287RB.pdf
page 4
May 11, 2011 | Consew 288RB-1
I need to know how to time it. It just sits in one place and sews. It won't feed the material at all. Doing a small braided cord and have to tug it to get it sewn. Tried to raise feet and every thing went...
If the feed dog stays in one position and just moves up and down, and doesn't pull the fabric through, press on the button in the bed closest to the needle bar. Hold it down and rotate the wheel. This adjusts stitch length/feed dog travel. There should be numbers on the wheel or under a flat metal panel next to the wheel. The numbers are for stitches per inch.
The problem you describe isn't timing, it's most likely stitch/feed dog adjustment.
Sep 30, 2009 | Consew 226R-1
My stitch length is not what I have it set for. I set it on 5
I assume you mean it stitches 6 or 8 when set at 5.
Because the number shown on the wheel says "5" doesn't necessarily mean 5. It's just an approximation. You'll note that when turning the wheel there's tension. The numbers are just numbers. It isn't a micrometer, its a sewing machine. So, you can simply adjust to get the stitch you want then make a mark on the wheel at that point. You may end up between 4 and 5, or between 5 and 6. No matter. Wherever you get 5 per inch is where the adjustment is.
Aug 05, 2009 | Consew 226R-1
How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Jun 16, 2009 | Consew 226R-1
Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Mar 14, 2009 | Sewing Machines
In need to know how to adjust my stiching and needle adjustment/ the bobing is jamming(not stiching)
Stitch length is adjusted by holding down the small button in the bed and turning the wheel to the desired number of stitches. The numbers are either on the wheel, next to the belt pulley, or under a small cover on top of the machine. Hold the button and turn the wheel either toward or away from you to get the stitches you want.
Bobbin jamming is either because of incorrect top tension or incorrect threading. Go to www.consew.com and get a parts and operation manual for free for a 224. It 's the same as the 226.
Mar 10, 2009 | Consew 226R-1
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Consew 226R-1 Logo
355 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
