Question about HP Compaq Business nx7000 Notebook
Blank screen after switching hp nx7000 on
The screen doesn't show anything. i have suspect that its the bios. is there any way to refresh the bios?
    President:
  • 1,188 Answers
You will find useful information and BIOS downloads here:
Notebook Does Not Startup or Boot Displaying a Blank Screen
BIOS update
Try the first link first. Update the BIOS after carefully reading all the instructions.
Posted on Oct 01, 2009
  • 250 Answers
If the laptop has been dropped, the light for the screen may be broken, making it look blank. If the screen glows, you can tell even if it's blank, it could be a few other things. If a ram stick or the processor is failed or not connected properly, it could keep the bios from starting. If you're not sure if the screen's broken, try plugging it into a regular monitor and see what happens. Check the ram sticks and make sure they're seated properly. Make sure the laptop is not running on battery power but wall power for the time being. To reset the bios, unplug the computer, take the battery out, and look on the bottom for a hole labeled reset. Put a paper clip in that hole, feel around for the button, and hold it down for like 30 seconds. Now put the battery back and plug it back in. If you see a message about a bios checksum error that means you successfully reset the bios. If that doesn't help try only one stick at a time, try it without the hard drive, etc.
I have hp compaq nx7000 laptop that i upgraded from windows xp to windows 7 (32 bit) I need audio driver laptop
Yo! I will have to direct you to a website where you can download anything for your computer.you can download drivers and applications from them.you can also visit HP website to download the driver. please follow the link below..
www.download.com
www.filehippo.com
www.hp.com
Aug 22, 2011 | HP Compaq Business nx7000 Notebook
Problem with the HP Compaq Business Notebook nx7000 PC Notebook Blank screen after switching hp nx7000 on The screen doesn't show anything. i have suspect that its the bios. is there any way to refresh...
its one of your start up drivers restart computer when first page is active push f2 then change your boot f12 then restart computer then push f12 then ask you to run windows again run windows.
Feb 07, 2011 | HP Compaq Business nx7000 Notebook
HP zv5430us laptop has no video. Blank
take the main battery out, does it run everytime on a/c line pack
power.??? this is first test of any laptop. test 1.
sure there is a chance but that is not step2..
test test to is while doing test 1, see if there is the screen prompts
in text as it did its whole life. "hit ESC key to enter setup(bios)
can you get the screen to show above,battery out?
yes, good do the ESC key, BIOS entry, .see BIOS work.
great , if yes, the the HDD is not booting windows? what?
NO, SCREEN STAYS DEAD NO MATTER WHAT.
Suspect now is the power pack. as low as $15 cost.
the pack is 19vdc, does it measure that? if not its bad. (or the pc is shorted)
at HP, the support ended. and is offically Retired
https://support.hp.com/us-en/retired-products
got any beep codes , or keyboard blink codes there?
does the fan run? and blow, are the vents lint free or packed.
Jul 14, 2017 | HP Pavilion zv5430us (PR466UAA) PC...
HP nx7000 display sometimes still or sometimes flickering horizontal lines then goes and says blank
It appears the video cable connector needs to be seated properly, it may be loose. The connector would be located near to bottom of the screen on the motherboard between the hinge and the top edge of the keyboard.
Depending upon the model of the laptop there is a plastic panel which houses push buttons and indicator lights that is located between the top edge of the keyboard and the bottom of the LCD screen. There are screws at the bottom of the laptop and possible screws on the back next to the hinge securing this panel. This panel would also have small plastic retaining clips locking it into place. You need a thin blade to lift this panel up, be careful not to crack the panel.
Once you remove this panel you see this video connector and cable. the connector may also be held in place with a screw and plate.
Jun 03, 2009 | HP Compaq Business Notebook nx7000
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
Hi. My HP nx7000 Notebook does not switch on at all
If you have warranty get it in for a new m/board ok
May 07, 2009 | HP Compaq Business nx7000 Notebook
HP Pavillion DV9700 Laptop Blank Screen on Boot Problem
remove battery,ac adapter and other external medias,then hold on power button for 30seconds
later
with ac adapter attached try to power on still probs ...then its bios probs need to use bootable disk or recovery disk of your laptop
Feb 20, 2009 | HP Pavilion dv6000z Notebook
HPNX7000. Blank screen when the labtop is on.
Try pressing Fn + F4. You might've switched the display to the external VGA port by accident.
Dec 28, 2008 | HP Compaq Business nx7000 Notebook
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
HP Compaq Business nx7000 Notebook Logo
799 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
