Question about Ricoh Caplio RR630 Digital Camera
What is difference between A & P on selector dial
  • 58 Answers
A is Aperture priority mode - you set the aperture the camera sets the shutter
P is program shift mode - the camera balances the aperture and shutter, if you raise one the other goes down an equal amount
Auto is same a P except you can't change settings.
Posted on Oct 01, 2009
I have a Elna air electronic 68, I am not able to use different function. Like thr preprogrammed.
Your AE 68 will have three dials across the front, from L-R, stitch selector, stitch width and stitch length. To sew any stitch with a sidewise needle movement, you will need to turn the stitch selector to that stitch on the selector, then turn the stitch width to between 3 and 4 and the stitch length to a similar setting, adjusting to get the stitch formation you need. To sew with the discs, set all the dials to zero, then insert a cam into the Elnagraph on top of the machine. Then turn the selector to the disc icon, and the stitch length around to the "S" and stitch width to 4.
Don't use reverse if using the elnagraph stitches.
Jul 01, 2017 | Elna Sewing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
The pattern (stitch) selector doesn't work when I turn it
it sounds like you need a new pattern selector dial & it wouldn't
hurt to have the machine checked to see if the internel part of the
dial is ok inside
Oct 11, 2012 | Singer Featherweight II 117
Can't move stitch selector dial on singer cg590 c sewing machine
The machine has a 'hold' in the blank (or red) posiiton. You have to push the selector dial in a little bit then turn it. If it is in the red position it will only turn clockwise.
May 31, 2012 | Singer CG590 Mechanical Sewing Machine
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Cyber Twin selector knob.
The selector knob may be a potentiometer or a rotary impulse giver device. In any case, it looks like the internal contacts are either dirty or oxydized so the value is changing in an erratic way which causes the unit to skip several presets at a time.
It would require a skilled technician to disassemble and clean the controller (if it can be disassembled in the first place), otherwise you will probably need to replace the preset selector knob entirely.
Regards,
Triarcuate
Oct 07, 2009 | Music
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Nov 26, 2008 | Necchi 3537 Mechanical Sewing Machine
Ricoh Caplio RR630 Digital Camera Logo
29 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
