Question about Car Audio & Video
I am looking for the handset wiring diagram for the Uniden UH015SX UHF radio, I ripped the handset cable out of the plug that attaches to the radio
  • 3 more comments
  • azztechalarm Oct 01, 2009
    I need the pinout configuration for the handset plug, the lead that plugs the hand set to the radio.
    I am looking for the mic pinouts for the uniden UH015SX uhf radio. I have pulled the cable out of the socket that attaches to the radio and need to know the colour to PIN. It has 4 wires, red,black,yellow, white and bare ground wire. its a 6 pin plug that connects to radio, Uniden won't tell me.
    All the wires have been ripped out of the mic cable at the radio end, so all i have is the mic with curly cord attached and 4 wires + ground snapped off at the other end. It's a six pin connector with broken solder joins at the radio end but only 4 wires + ground on mic lead.
    Just to clarify. All wires of the microphone are disconnected at the RADIO END, I have a multimeter, so can test pinouts but I thought some where in this mass of information called the internet some-one could tell me what colour goes to what pin.e.g. red = 1, black = 2, ground = 5. Uniden refused to tell me what the Pin outs are.
    Do you have an email adress that i could send you pic's?
  • 5,807 Answers
Hi, Uniden UH015SX UHF Radio what part of this handset are you having trouble? or the other mic you are using? do you have the original like these on the pic? how many wires got loose?, do you have receive? or TX?
Posted on Oct 01, 2009
  • 10 more comments
  • Rommel Cana
    Rommel Cana Oct 01, 2009
    do you have a multimeter?
    can you measure voltages on the terminals?
  • Rommel Cana
    you need to start with the ground
    then the TX
    last would be the audio (mic)
    do not use voltage over 5V
  • Rommel Cana
    white might be audio
    you only need 3 wires
  • Rommel Cana
    once you found the TX audio is the other with a supply voltage of no more than 8V
  • Rommel Cana
    what color goes to TX?
  • Rommel Cana
    you can momentary short ground and one of the pins to find TX
    TX = transmit
  • Rommel Cana
    white maybe audio
  • Rommel Cana
    send it to experts@fixya.com instruct them to forward the picture to palaboy
    try to have a small wire one end to the ground,
    try to jump one at a time the pins . once TX appears we will find the audio next
  • Rommel Cana
    tell me the voltages on
    red =?
    black = ?
    white = ?
    yellow = ?
  • Rommel Cana
    there are pins that have voltages on it
    try not to use 8 volts , use 5V if there is as TX
    short temporary or momentary to ground
    ground = chassis of the radio
  • Rommel Cana
    concentrate first on the panel of your radio, forget for time being your mic
    you need to find the voltages i am asking
    short a wire from the chassis to any of the pins, only momentary
  • Rommel Cana
    and watch closely on the panel it will show TX or transmit
  • 11,896 Answers
Yellow is directly to battery.
Red is for accessory
Black is ground.
Blue and orange are not used.
Wires with stripes are ground speaker wires
Plain wires are positive speaker wires.
You can go to installer.com and see what wire is which on your car itself. stereos as well. google images also
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
My uniden uh015sx wont recive but will transmit ' new antena new antena wire and have swoped hand piece still same
First proceed with manual programming steps using squelch/volume knob. Second search for local tech service.
Dec 03, 2015 | Uniden Radio Communications
I pulled u uhf out of my vehicle and replaced it with a pro 520 xl uniden uhf but it won't work.
Check your electrical connections and your antenna set up first. Then if you still have a problem, check your mic/mic plug. Lastly, check your programming. If you have ignition sense programmed into the radio you will need to wire it accordingly, so it will sense the ignition of the vehicle.
Best regards.
Sep 13, 2013 | Motorola UHF 1-Watt, 1-channel Radio
I want to reset my uhf cb to factory setting model number uh015sx
hold POL and HOLD and turn the radio on after the screen resetts 3 times turn off then on again ,,, dont listen to dribble about hills ext ,,,,
Mar 20, 2013 | Radio Communications
Uniden uhf 15sx radio how to wire up
Hi,my name is John. The other red wire is positive also, and the black is the negative or ground wire......hope this was helpful....Rate this on the four thumbs-up.....John
Jul 18, 2010 | Uniden Radio Communications
I have Uniden uh015sx radio and I can't program scanner
This Australian model CB/scanner operates in the UHF band only. Frequency coverage for the scanner function is 400-512MHz. Need the operating manual? You can download/print it here:
http://www.uniden.com.au/resources_main/pdfs/uh015sx_OM_2yrWarranty-Updated.pdf
Bill B
May 12, 2010 | Radio Communications
My Uniden uh015sx uhf cb radio only has about 50m range.What could be wrong?
that's pretty far. I would say the problem lies in your antenna. Is it tuned properly? Is it up high? Are there hills around you blocking your signal?
When it comes to distance, height is might. I have seen bare foot 4 watt radio get more range then your radio. Its all about the antenna system.
Apr 04, 2010 | Radio Communications
This is a UHF only radio, with coverage from 400 to 512 MHz. Need the operating manual? You can download/print it here:
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/uh015sx_OM_2yrWarranty-Updated.pdf
Bill B
Mar 20, 2010 | Radio Communications
UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Jun 09, 2009 | Uniden Radio Communications
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
