Question about Sony PlayStation Portable (PSP) Console
Problems after updating ver3.80
I've recently updated to version 3.80 on my white PSP. Ever since, It says that there is no saved game data and will not let me save a new file. The RSS Channels that I've saved to the memory stick are not displayed anymore. And it will not let me save new ones. Whenever I try, it says "Save failed" and displays a number. In other words, my PSP no longer wants to save anything to the memory stick.
My poor PSP has turned into nothing more than a 200 dollar music player that looks at pictures and plays videos... Help?
Note: I've checked all my files on my computer, and all my game and RSS Channel files are still saved to the memory stick.
Re: Problems after updating ver3.80
I have a cfw psp ver 3.71 m33 -2 and every time i trie to play a game it says region code not corect what do i do now ??????
Posted on Jan 25, 2008
  • 79 Answers
Possible solution:
You can try to have your memory stick content backed up to your computer local hard disk, and then do a format for the memory stick from your psp, as well as full reset, (should be found under the setting=>system setting menu) then, copy the backups back to your memory stick.
Give a try and let me know if it works
Posted on Dec 20, 2007
0 characters
3 Points
Hello There, :) i've updated my PSP to version
you wont be able to play .iso files(games in the iso folder) because you updated to Sony's official firmware. but in order to play .iso files again you will have to hack you psp and make sure its running cfw(custom firmware).
May 15, 2011 | Sony PSP 2000 Console
How to install Firmware on your Sony PSP
<li> <p>Visit the sony PSP website by going to:<br /></li> <li> 2 <p>Click the Download Now button, which is located under Step 3 under the "Download Procedure."<br /></li> <li> 3 <p>Verify that the file will be saved with the name "EBOOT.PBP" and save it to your desktop.<br /></li> <li> 4 <p>Connect your PSP to your <a href="">computer</a> via the USB cable. When the cord is plugged in, select "USB Connection" under the Settngs menu on your PSP.<br /></li> <li> 5 <p>Let the PSP window open up on your desktop. This will take a minute, so be patient. From the window, select "View Files."<br /></li> <li> 6 <p>Select the Games folder from the open window.<br /></li> <li> 7 <p>Select and save the file into the Update folder. If there is not an Update folder already made, make one by right clicking your mouse and selecting "New Folder." Save the folder with the name "Update."<br /></li> <li> 8 <p>Safely remove your PSP from your computer by right clicking and selecting "Safely Remove" from the green arrow icon in the tray on the bottom left of your computer's screen.<br /></li> <li> 9 <p>Use the right arrow key on your PSP to highlight the Game icon from the PSP menu.<br /></li> <li> 10 <p>Scroll down and click on the "Memory Stick" icon. This is usually the last icon in the list.<br /></li> <li> 11 <p>Click the PSP Update icon and follow all of the instructions that it tells you to follow. You will now have the latest version of firmware on your PSP.<br /></li> <br /> <span>Tips & Warnings</span> <ul> <li> After the new firmware has been installed, you can delete the update from your PSP to free up space.</li> <li> None of your saved files will be deleted from updating firmware versions.</li></ul><br />
on Jan 04, 2011 | Sony PlayStation Portable (PSP) Console
How do i update my psp so i can go on playstation store when i dont have the instuctions
  • System Update »
    Update using the PSP® system's [System Update] feature.
  • Update using a PC »
    Download the update data to a PC, and then save on Memory Stick™ media or system storage. Start the saved update data on your PSP® system to perform the update.
  • Jul 03, 2010 | Sony PlayStation Portable (PSP) Console
    My memory stick cannot read the game file but it can read other files like save data file,image,sound and video.
    my psp 2000 hav some problems after update to new system 6.20 , before that is system 3.++ . before i update, i can play some of the game, and i wish to play AVATAR so i have to update my psp system in order to play . . after i update my psp to system 6.20 , i can c any games in my psp any more... is there any problem?? is tat the system only support legal games?? do i really nid to download legal game oni can play??? help me pls...
    Feb 07, 2010 | Sony PlayStation Portable (PSP) Slim...
    I downloaded the update but the pc cannot open the file . the updater is called eboot. i have it in my pc but cannot open it
    The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
    Download procedure
    1. Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
      • Connect the PSP® system to the PC using the USB cable
      • Connect a commercially available Memory Stick USB reader/writer to the PC
      • Use the Memory Stick slot on a PC
    2. Create a folder for the update data on either system storage or Memory Stick™ media.
      Using your PC, create a folder named "PSP". Within the "PSP" folder, create a folder named "GAME". Within the "GAME" folder, create a folder named "UPDATE". (Folder names must be in all uppercase letters).
    3. Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step 2.
    You must save the downloaded data as noted in these instructions. If you do not save in the correct location and with the filename shown below, the system will not recognize the update data.
    • Filename: Save as filename "EBOOT.PBP"
    Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
    How can i update the firmware of my psp in firmware 6.00
    1. Get the firmware upgrade data. You can get one on the official PSP website[1]. When clicking Download Now, remember to Save it, not open it. The file name should be EBOOT.PBP Save somehwhere where you can access it easily e.g. Desktop, My Documents, C:\. 180px-psp_619.jpg magnify-clip.png
    2. Plug in your USB cable that you have bought or had to your PC or Computer (same thing). On your PSP you should go to System Settings and on the 2nd from the top press (X) on USB Connect. On your computer it should say something like New Hardware detected USB Mass Storage Device. In My Computer there should be something named "Removable Disk"
    3. Click on the Removable Disk and inside there might (might not be) be a folder named "PSP". Click on the PSP folder to go inside of it and inside the PSP there might be a subfolder named "GAME".
    4. Inside the GAMES folder, create a new folder and name it UPDATE in caps, no spaces. Inside that UPDATE folder drag and drop that EBOOT.PBP that you downloaded earlier.
      • If the PSP folder and GAME folder are not there, you can just create them. Remember that the folder name MUST be in CAPITAL LETTERS and the the GAMES folder is INSIDE the PSP folder, don't mess this up or your PSP will ignore your folders
    5. "Safely Remove Hardware" -- this should be in your Icon Bar on the Right side of your start bar.
    6. Fully charge your PSP and plug it into the wall. Go to the Games Area; there should be an Icon that says Memory Stick Choose that by Pressing "X" and you'll see PSP Update Version *.** (* meaning what version you've downloaded onto your PSP).
    7. Press PSP Update Version *.**, It'll clear the screen for a few seconds and come back on saying "PSP System Software Version *.**" It has a "Start" option or says that you already have that version. Press the Start if you want to upgrade.
    8. Go through the User Agreement and start the upgrade Process. When it starts, remember not to even touch that PSP. Just leave it alone on the floor, desk , chair, etc.
    [edit]Steps-Method 2
    1. Go to network update, under Settings.
    2. The PSP searches for possible updates.
    3. When the updates come, bypass all agreements etc. by pressing X button.
    4. Let it update in peace.
    [edit]Steps-Method 3
    1. Make sure you have a UMD inserted.
    2. Go to game and choose PSP update.
    Oct 28, 2009 | Sony PlayStation Portable (PSP) Slim...
    The problem might be that you used the file name EBOOT.PBP.PBP to save it.Delete the file name you use in saving it on your pc and re-type EBOOT.PBP.
    Dec 07, 2008 | Sony PlayStation Portable (PSP) Console
    the system on your PSP is Hacked, you have to update to a hacked version :)
    search in google for hacked PSP system sofware and follow the instructions ;)
    and dont forget to mention your psp version name in search.
    Jul 18, 2008 | Sony PlayStation Portable (PSP) Console
    Games gone after update
    Your save game data should be stored in a folder called GAMEDATA in the PSP folder, if they are in a slightly different folder or have moved then make a GAMEDATA folder and cut them all into it. They should then show up in your psp's game data on your psp.
    Hope this helps, if not then please provide more details of the situation and I will investigate further for you.
    May 12, 2008 | Sony PlayStation Portable (PSP) Console
    Update for sony psp 2000 ver. 3.71 m33-2
    visit the website
    May 06, 2008 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    89 people viewed this question
    Top Sony Video Game Consoles Experts
    Troy Gorman
    Troy Gorman
    Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
