Question about Miller Welding Tools
Big 40 face plate?
Have Miller Big 40 gas, 4cyl,face plate without gauges late 70 model. Where can I purchase a replacment face plate Model 900 955. Amperage Range reads 250 on top with max on bottom. Fine current reads 0 thur 100
SOURCE: Miller Big 40 will not weld and has no current at the A/C outlet
ok boy your welder have a riostathic control check contacts of your control maybe have dirt or grease
Posted on Mar 01, 2009
  • 3600 Answers
SOURCE: Is the arc force determined by the amount of
The voltage is controlled three ways, your manual setting you fine tune setting and the distance you have from the work space on most welders the fine tune only adjusts about 5 volts some newer models goes to ten but lets say 5 so if your running 7018 1/8 inch rod at 105 amps you may have to adjust it with the fine tune knob to half or 3/4 of the way to get the right flow pattern if using this pattern ccccc if your using zig zag so the distance is important it should not be more than twice the wide of the rod depending on what type of welding posting your doing overhead or vertical or flat position. If you need more clarification let me know.
Posted on Aug 20, 2009
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
brainyass
  • 242 Answers
SOURCE: oil pressure gauge 2000 jeep cherokee sport 4.0 6cyl.
It's probably the oil pressure switch. I have to replace min every 5 years or so because it does the same thing. Mine is mounted next to the filter on my '93. It's a little black thing with a plug in the end. You can get one at autozone for about $40.
Posted on Oct 24, 2008
jyackle5
  • 8197 Answers
SOURCE: Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
Posted on Dec 17, 2008
Need spark plug gap setting
You can consult the parts house where you purchased the plugs and they will probably have the exact gap information for the model, make and plug type. Now days about 50 thousands is pretty well normal. If it's an older model try about 35-40 thousands. The difference is the newer models have a hotter ignition and run at a lot higher voltage. Also the plugs are designed different on some of them. P.S. you can get a little disc about the size of a half dollar that starts out at pratically '0' and goes up liner to about 65 - 70 thousands. Costs about a buck and will fit on your key chain. dhgill1949
Jun 04, 2011 | Land Rover Discovery Cars & Trucks
The oven wont heat up and the glow plugs are working and the gas is on
Most often the problem is the ignitor is not drawing enough amps to open the safety valve. Without knowing your model # , your valve could be rated 2.5-3.0 amps or 3.2-3.6 amps. If you can access one of the wires on the ignitor , you can read with an ammeter. Proper amperage will be printed on sticker on side of valve. Be sure to replace ignitor with one of proper amperage.
Jan 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My gas bake burner won't ignite.The igniter is on.Gas Range Jenn-Air model#JGS885OADW
If the bake ignitor comes on - check the amperage on the bake ignitor wires when it's on. Amperage should be 3 - 3.6A. If less than 3A - replace ignitor.
Ignitor part numbers (any will do, but the first one is a direct replacement): 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
All those are interchangeable, if you can splice the wires.
Apr 03, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
My plate does not rotate when in use
This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can usually purchase replacement parts at the any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Dec 17, 2009 | Microwave Ovens
Replacement motherboard for the 1600sc, I need one with SATA on it is there such a board out there to replace the original motherboard
There are a huge range of motherboards to choose from.
The mounting holes on the motherboard will match the desktop mounting plate, these are standard configurations.
Stick with the well known brands and with the functions that suit your requirements.
My choice of brands are Gigabyte, Intel, MSI. Most of the late model motherboards have SATA disk controllers.
If you are into gaming and video editing etc. go for a motherboard without a built-in graphics card and purchase a separate high end graphics card.
Nov 16, 2009 | Dell PowerEdge 1600SC Server
Trail blazer gas gauge reading empty when its
The sending unit in the gas tank must be replaced it may be possible to gain access through the back storage compartment by lifting up the rug look for an access panel with a couple of screws holding the plate on remove it and you should be able to look down through and see the gas tank and a couple wires going to the sendind unit unscrew the screw remove and replace if access plate is not there then it is possible the gas tank must be removed to do the job purchase a Haynes repair manual.
Nov 06, 2009 | 2002 Isuzu Axiom
The motor on the Kenmore refrigerator is running continuously. How do I stop it? I just cleaned out the dust from the coils underneath and replaced the kick-plate at the bottom
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
May 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Amperage Requirement
an electric stove requires a 40 amp double breaker in the fuse panel. good luck. Also read the manual to make sure.
Dec 16, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Welding Tools Logo
612 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
