Question about Cameras
Hi!pentax problem Hi! My Pentax OptioS10 got wet inside my luggage during the typhoon..I removed the battery and memory card and air dried the camera thoroughly using electric fan without touching or opening the camera.Likewise, I charged the battery and it was a little bit hot.I inserted the battery and tried it on.It started but after a few seconds it automatically shuts off.I tried it a few times and got the same result. 1. Is there a problem with the camera or the battery? 2. Where to send for repair here in the Philippines?
Water in camera
Remove the batteries and let it dry for good. To be sure all the damp on electronics evaporated. Put the camera on warm place (not to hot). You need to open all doors (SD card, battery etc..) even back cover to let the damp go out. Blowing dry air may accelerate the drying process.
Install batteries when you sure all the water trapped inside has evaporated completely.
Sep 23, 2013 | Pentax Optio M20 Digital Camera
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
How do you troubleshoot a pentax camera? My camera
A wet camera should not be turned on. Remove as much water from the battery and card compartment as possible. Bury the camera in a bowl of rice for a week before trying it.
Aug 07, 2010 | Pentax Optio S7 Digital Camera
Upgraded to Windows 7 & it no longer recognises my Pentax Optio S5i camera ? Cannot download my photos since installing Windows 7. Can we get updated software for my camera ?
HI there there try to download the windows 7 camera driver from pentax website. It will start work then. Another way is remove the memory card & put in in a card reader then you can also transfer all photos from card to computer For further help ask me . Thanks.
Mar 23, 2010 | Pentax Optio S5i Digital Camera
My Pentax Optio 450 retains only one photo on the memory card
Have you tried using a card reader to download the pictures from your card to your computer? I bet the pictures are there.
Jan 10, 2010 | Cameras
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
Jun 10, 2009 | Pentax Optio 430RS Digital Camera
Memory card error when I turn on camera
oops.. looks like many card errors, as just now i gave reply to 2
Test the memory cards using external card readers connected to computer/laptop and see if it works.
If it doesn't, then it can be formatted from computer and tested on Pentax again.
If still it doesn't work on Pentax then it can also be a small issue of contacts inside attracted dust. You can try using blower to clean dust if any in the place you insert the memory card and try again.
If it doesn't work then it it needs visit to some experienced person/technician/mechanic.
May 30, 2009 | Aqua Pentax Optio S12 Digital Camera
How??
hi cacrom3,when you slide the battery compartment open the memory card is be side the batterys just push it down and let it go it should pop up so you can grab it.
Dec 10, 2008 | Pentax Optio E30 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
