Top loader washer won't fill with water
Top loader washer starts to fill but keeps stopping then starts again and stops until the alarm beeps
  • 11,896 Answers
Either the water level sensor is faulty or the selector switch is bad.
Servicing the Water Level Control Switch
This is another control panel switch, usually located next to the temperature switch. There is a small hose connected to this switch, and sometimes this hose becomes loose and falls off the connection. When this happens, the water in the tub usually overflows. To solve this problem, cut about 1/2 inch off the end of the hose and use a push fit to reconnect it to the switch.
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected.
Posted on Oct 01, 2009
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
GE top loader washer water keeps running will only cut off at faucets"
If disconnecting power does not stop the water fill, replace the washer's inlet water valve. It is the part the fill hoses screw onto on the back of the machine.
May 20, 2009 | GE WBSE3120B Top Load Washer
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Machine keeps doing one step of cycle and beeps
Hi there.
There may be a problem on the control board (you suspected yes?)
Or it may be waiting for a certain condition.
Basically it's a very simple computer.....-
Select program (sequence of events)
Water fills.....Untill weight sensor says stop.
Water then heats........Untill temperature sensor says stop.
Goes through a sequence of motor spins....untill time out.
Pumps out.....untill floatswitch says empty.
Does same again ...or something else.
Either the control board has a fault - so just doesn't advance, or there is a faulty sensor that never supplies the info needed to advance.
Try and spot at what point it stops and waits. This will pinpoint what it's waiting for.
If it's waiting to heat up - and the element has blown. it will be stone cold. This is a common fault.
Let me know how you get on.
Richie.
Jun 14, 2008 | Washing Machines
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
