Question about Fujitsu PRIMERGY TX150 S2 (VFYTX150S2002B) Server
System board voltage has exceeded the critical threshold
2 Suggested Answers
  • 86 Answers
SOURCE: Hi. pls help me to fibd a solution to this
This might something to do with the voltage sensor event messages monitor the number of volts across critical components. These messages provide status and warning information for voltage sensors for a particular chassis.
The voltage of the monitored device has exceeded the critical threshold.This is critical you were being asked to do F2 for the reason that you have to Clear NVRAM or Clear the BIOS or probably you are into some hyper threading / its a defense mechanism of the computer to detect thermal problems . Might as well you may check the ventalation on the system as well as the performance of each part in the system .
ERNZ
Posted on Feb 10, 2010
I have a AEG F88060VIOP dishwasher - showing error coded ,00 and beeping. Not listed in manual - can anyone help id cause and fix please? Thanks
Fault code "i00" means "Low mains voltage"
The electronic board makes sure the dishwasher operates within certain voltage limits. If during a cycle the voltage drops below the lowest limit, the electronic board suspends all loads and interrupts the cycle under way. The "i00" alarm is then triggered. The lowest main voltage threshold is 180 Volt. If the voltage goes back to over 186 Volt, the electronic board cancels the error status and the cycle
resumes. The "i00" alarm is also deleted.
If the mains voltage continues to exceed the maximum threshold, the electronic board does not do anything.
My suggestion is to call your local electrician to check the voltage in your home.
Dado
Feb 23, 2015 | AEG Dishwashers
HYUNDAI MATRIX GSI TD WONT START FROM THE KEY, BUT WILL START AND RUNS FINE IF YOU TOW IT A FEW FEET
Maybe your system voltage while cranking is dropping below a certain threshold that your ignition system requires to both spin the starter motor and run other critical system components. Assuming this is the diesel model, you may benefit from measuring voltage while cranking or attempt a jump start (get reserve power from another vehicle that has the same system voltage as yours). The fact that a bump start works, and normal start will not leads to this advice. Good luck.
Nov 28, 2014 | Hyundai Cars & Trucks
Sportsart treadmill error 7
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 04, 2014 | Exercise & Fitness
Sportsart 3000 treadmill problems
Mar 25, 2013 | Sportsart Exercise & Fitness
My inverter (500 va) (battery based electric generator for power backup) keeps on charging batteries even when the charging light goes off making the inverter, wires and battery very hot.
This a possible failure of the voltage detection circuit in the inverter main board and requires the fault be identified by checking the voltage/current feed/limiter to the battery.
Once when the battery voltage has reached the threshold set up the charging should stop and then the circuit will analyse the voltage on the board to trigger the charging to be put ON.
This can be a failure of the detection circuit and if not checked can damage the battery.
Jun 20, 2011 | APC American Power Conversion Back Ups Es...
B1231 crash detected lgogitudinal Accelaration
I would assume the acceleration sensor, (probably a mercury tilt switch), is improperly mounted. It has to be perfectly vertical.
Jun 08, 2010 | 2007 Mazda 3
Trouble code P0172
Diagnostic Trouble Code (DTC) P0172
Fuel Trim System Too Rich
Features of the Circuit
  • There will be a deflection in the adaptive terms which is capable of identifying a slow default emerging in case the adaptive value threshold is permanently exceeded.
  • As the lambda controller supersedes the adaptation threshold, the two time counters (one for the rich side and another one for the lean side) will be kicked started.
  • The error or the discrepancy will be detected the moment either of the time counters attains the highest value.
  • This test is undertaken keeping in mind that a failure that can exceed the adaptive terms can be generated.
  • The following two failures need to be created.
a) A lean side deviation: P0171
b) A rich side deviation : P0172
  • Determining the limit good and the limit bad for each kind of failure therefore becomes mandatory.
  • For any given failure, it is advised to measure the emission threshold until the legal emission thresholds are exceeded.
  • It must also be noted that the problem is because of the emission thresholds required, which is pretty complicated and the system needs to be affected by some disturbance so that the emission thresholds may be exceeded.
  • A judicious calibration has already made the tuning but, since the regulation does not approve of such a move it is mandatory to forcibly generate some visible material malfunction like (fuel pressure regulator, fuel injector, air leakage...)etc.
Apr 15, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Hi. pls help me to fibd a solution to this problem. system board voltage has exceeded the critical threshold. and how does it cause this problem. during i boot up my server that message appear and it give...
ERNZ
Feb 10, 2010 | Fujitsu PRIMERGY TX150 S2 (VFYTX150S2002B)...
Hello sir, the system zone-2 temp., always keeps flashing in red.
It is a motherboard problem. But you can disable that alarm from the BIOS. I would simply raise the upper threshold in zone two from 56 to 60 if I were you. If it still flashes red put it back to 56 and disable it.
Apr 26, 2009 | Intel D865GBF Motherboard
Start and stop
Hi and welcome to FixYa,
Offhand that would be a normal reaction from the bike. When the battery is removed with the engine running, the voltage from the regulator will shoot up, the ignition system is designed to clamp down if the supply voltage is above its threshold. Additionally, the shutting down is to your advantage, since the voltage will go up, most of the bulbs, electricals and on-board electronics would burn out if subjected to prolong over voltage supply.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | 1993 Honda CBR 1000 F
Computers & Internet Logo
1,077 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
