Question about Microsoft Visual Basic 6.0 for PC
Database of a library management project - Microsoft Visual Basic 6.0 for PC
  • markie_09 Mar 04, 2010
    how to make database management?
    Sniper:
  • 73 Answers
I just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect
You must connect to a database to utilize Primavera. You can not bypass this portion. So, Either remove the Database and reconfigure, or in the "Configure" Screen you can Name a new DB and use it. I would suggest that if you do not require 2 DB's not to have two. "The Oracle Database 10g" application that is installed with P6 (In your 'All Programs') will give you some DB manipulation options. Other wise refer to the TenSix link to clarify DB Config
http://www.tensixconsulting.com/2013/03/primavera-p6-database-connection-configuration-details/
Feb 13, 2013 | Primavera Contractor 6.1 Full Version for...
About projects
Video Rental Library
Library Management
Hospital Management
Hotel Management
are some of the common topics. YOu can opt for Video Rental Library. First identify factors that involve in Video Library. Prepare a note on how the video rental works. Then develop a sketch of what forms you will need on a peice of paper. Identify what databases you will need. Then proceed.
Jul 19, 2010 | Microsoft Computers & Internet
We have an exsisting Access 2003 database. My coworker was given a new computor and now when he trys to use the database he gets the following prompt: "The expression you entered has a function name that...
You are probably missing a private library on the new computer, or have an incomplete installation of Access. Then simple functions like Date() or Trim() don't work, or user defined functions in a private library cannot be found. Your access project probably uses a special library that needs to be copied to the new computer, and it needs to be properly referenced by the Access project.
To see what libraries an Access project has referenced, open any code window (e.g. press Ctrl+G), and choose References from the Tools menu.
If a library is marked MISSING, click the Browse button, and locate the correct file for the library. The table below lists the files for the crucial libraries of your version of Access.
If the library is not even shown, you may need to re-register it. Click the Windows Start button, and choose Run. Enter regsvr32 followed by the full path of the library file. Include quotes if the file name contains spaces, e.g.:
regsvr32 "c:program filescommon filesmicrosoft shareddaodao360.dll"
Occasionally, the problem is not solved until you unregister the library and re-register it. Uncheck the missing library in Access. Close Access. Issue this command, and then the one above to re-register it:
regsvr32 -u "c:program filescommon filesmicrosoft shareddaodao360.dll"
Re-register it (as above). Open Access, and select the library reference again.
May 10, 2010 | Microsoft Office Access 2003 (077-02871)...
I am using windows 7 64 bit home edition i cannot able to install the primavera project management release 6 ( cannot configure database)
it may be your pimavera project mangement not to support 64 bit it can be it support 32 bit reinstall you primavera project management release and then restart your compute.frist see the configuration of your software database
Apr 03, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
Can't configure the database connection for Primavera p6
i just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect to the database. Would you like to configure the database connection now?" How do I get around this challenge? iam using vista
Feb 05, 2010 | Primavera Contractor 6.1 Full Version for...
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
How to connect my database to my project?
use Excel library at following location.
D:\Program Files\Microsoft Office\Office12\EXCEL.EXE
Microsoft Excel 12.0 Object Library
Jan 05, 2009 | Microsoft Office Standard for PC
Send me the related titles to develop a projects in c,c++,vb
in C/C++ you can have projects related to system/hardware, maths and engineering.
while in VB you can create Database/Interface oriented projects. The related titles are :--
C/C++
1. Serial/Parallel port communication
2. Automatic weight entry from Weighing Machine
3. Your weight on different plannets
4. PC based PH Meter
5. Electronic Punching/Kicking pad to measure power of martial arts/boxing players
6. Electronic man counter
VB
1. library management system
2. Video Library
3. Virtual Library
4. Automated Parking Management system
5. Automated Car security check (Bomb finder)
6. Automated ID Card generator
7. Face recognition responsive system
Dec 08, 2008 | Computers & Internet
C programing
Try working on Management Software - School Management/ Library Management - These are a few ones where you can test you knowledge to limits - Like creating your own database file,naintaining indices etc.
Oct 31, 2008 | Computers & Internet
Microsoft Visual Basic 6.0 for PC Logo
602 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
