Question about Kyocera Mita FS-1020D Laser Printer
How to clean toner waste? - Kyocera Mita FS-1020D Laser Printer
  • 11,896 Answers
Rubbing alcohol and cotton swab on the contacts. Or you can purchase a cleaning kit which has basically same stuff
Posted on Oct 01, 2009
2 Suggested Answers
SOURCE: waster toner tank full/not install
The Waste Toner Cartridge must be VERY clean, especially around the "bump" directly below the left side hole. After I CAREFULLY emptied the old toner out, I used air compressor to clean every bit of toner out from inside. Then I wiped the whole area around the "bump" where the sensor "sees" if the tank is empty. Even a slight film over the area will not allow for reuse. If you do this, it works every time.
Posted on Apr 06, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Solve this problem error code e000019-0000 is this but i can't solve this
E000019-0000 is "waste toner box full" error message. It can be reset by removing and cleaning the waste toner box.
What is Waste toner?
Some amount of toner still remains on drum even after image has been transferred to paper. This toner is not reused and sent to waste toner box instead. When waste toner container is full, E000019-0000 displays on the display panel to alert the user.
Where is Waste toner box?
Location of the container might be different for each model. In Canon IR 2200, it is located on left rear corner, just behind the cover. Dispose off the toner and clean the container thoroughly. Don't forget to clean the neck area of the bottle. After reinserting the container, restart the machine and error E000019-0000 should have vanished.
Nov 16, 2015 | Office Equipment & Supplies
Cleaning waste box in toner
I don't recommend cleaning a waste toner bottle but if you do just pull it out and empty the toner out its very messy for don't wear anything you don't want to get dirty
Aug 08, 2014 | Kyocera FS Office Equipment & Supplies
Reset wast toner box on 9970cdw
Remove the full waste toner box per manual. Wear breathing protection as there will be toner dust in the air. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth. Place the box flat on bench to inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out. Replace the cover and 6 screws and replace the waste toner box in the printer. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jul 03, 2014 | Brother WT300CL Waste Toner Box
Reset Waste Toner in a Brother
  1. Remove the full waste toner box per manual.
  2. Wear breathing protection as there will be toner dust in the air.
  3. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder.
  4. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth.
  5. Place the box flat on the bench and inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out.
  6. Replace the cover and 6 screws and replace the waste toner box in the printer.
  7. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jan 24, 2014 | Brother WT300CL Waste Toner Box
Waste toner box full message after changing the waste toner box
When you removed the waste toner bottle, there is a sensor inside the copier. When you remove the waste toner, look to the opening where the top of the waste bottle was, clean that area and return the bottle and turn the copier OFF then ON. Good Luck
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
Aug 23, 2017 | Xerox Office Equipment & Supplies
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Waster toner tank full/not install
Feb 23, 2009 | Samsung CLP-500 Laser Printer
Waste toner message will not clear.
sir,
You open the front cover, there you can see the plastic bag. on the side of the cover you can see the intruction regarding the removing and refixing. actually it will be in white like colour and having a black bottle cap.
And also after you taken the waste toner catridge. you can see one sensor below a pipe like that which is projecting from the drum unit , it is the waste toner path. Inside this the waste toner auger will be there. you just clean the sensor because you may also get the waste toner error by the sensor.
1. sensor below the auger after the waste toner catridge.
2. waste toner catridge outside and inside. dispouse the toner and also clean the otside part will cloth , beause some projections some holes like that will be there. i told na that sensor will be passing the signals through this waste toner catridge projection. If any toner in that projection then also the same. Be causreful while you are disposing the toner. You may intake and also your properties may be having the black coating like that.
any clarifications mail me at ramanathanr@integramicro.com .
Nov 17, 2008 | Toshiba e-Studio 350 Copier
Kyocera Mita FS-1020D Laser Printer Logo
245 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
