Question about HP Compaq Presario V2000 Notebook
My mother board in out side of the cabinet work properly but when i put in cabinet it do not work only start pc then hang..
  • 615 Answers
Dear Sir,
It seems to be problem with your cabinet,some circuits of mother board may contacting metal surface of your cabinet,it may cause malfunctioning of your motherboard.
So before putting the mother board in to the cabinet,use some bedding material like cellulose paper,it prevents contact of motherboard circuits to the cabinet surface.if also problem remain unsolved may be problem with *********** board shows problem when it stands vertically.
I think it helps,if you have any problem leave a feedback we were happy to assist you.
Good luck
Posted on Oct 01, 2009
I need to replace my ram memory in my computer
open ur atx cabinet box opposite side from the mother board
then release the lock both of side
and remove old ram then fix newone
u must see the lock
ur ram not properly coming beep sound
Jun 22, 2011 | MPC Computers ClientPro 365 PC Desktop
HP Compaq laptop cabinet fully damage but sytem working fully damage what do
so what i am understanding is that your system is fully operational but the tower is cosmetically damaged. this is quite a job. if you are wanting you can buy whats called a mid atx computer. case. you can get these at a bustbuy or any computer store. you then would swap out the case. this is quit a job. i would first start with taking out the power suply. make sure you label all the wires as what drives and were on the mother board they go. so you know were to put them. i then would look into then taking the drives out one by one. you want to make sure you keep all the screws. a hang way to do is put the screws back in holes after u get piece of equipment out. the next step would be the mother board. there are four to six screws holding this down. you would be able to take this out. then all you do is put in in the new computer case. i would highly suggest getting a antiseptic strap as well as when you take out the mother board be very careful to just touch the sides.
Jan 06, 2011 | HP Compaq Presario SR1300NX (PP195AA) PC...
The screen has two lines popping up on the right side, one a red line and another a white line.however this is not affecting the usage but i am worried as to why this has happened and what it may lead...
If your screen has lines then it is the problem of RAM .
Please follow the below steps and you can fix your problem.
1. First unplug all the power cables to avoid electric shock.
2 . Now open the cabinet cabinet and look for the Ram on the mother board. It looks like a long chip.
3. Take the Ram out of the slots very carefully, you can do it by UN clipping the side locks.
Take it out and clean it with cotton cloth and put it back
4 .Place it properly push it in the slot and let the locks be automatically come up and grip the RAM.
Now start the system if the lines come then just place the RAM in other slots on *********** board.
After you are satisfied close the cabinet and you are done.
Hope you are satisfied with the solution.
Thanks.
Nov 24, 2010 | Acer Computers & Internet
How to reset my Dell OptiPlex GX520 PC Desktop Bios password
if you can open the cabinet and there on the mother board you will find a CMOS battery (round one) take that battery and keep it out for around 3 mins and then put it back properly - start your computer - BIOS password will be reset .
Oct 04, 2010 | Dell OptiPlex GX520 PC Desktop
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
My PC don't start,the power give a corect values to voltage
just take the ram out and put it back. sometime when the ram hangs which wont let the pc start. and another solution for it try disconnect the power supplly plugs and reconnect them to motherboard. and switch it on hopefully it will start.
Mar 30, 2009 | Computers & Internet
Start up failure;
try to start in safe mode using F5 at the time of window booting
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Mother board
Hi FRND,
You need to open the cabinet or PC system after that just have a look at the CMOS battery remove it and start the PC system for 5 to 15 second…
connect the Keyboard and mouse to the system have a look at the LED’s at the right hand side of the keyboard it it flash the power ok from the motherboard try using the replacing one by one … try replace keyboard & mouse might be short in side…
Jan 07, 2008 | Mercury P4VM800M7 Motherboard
HP Compaq Presario V2000 Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
