Question about Canon MP610 Photo All-In-One Printer
DVD/CD printing not centreted - on new MP610
The print on any Disc label is not centered eg white gap on left & bottom plus ink on the edge on right side ( inner & outer)
Adjusted DVD/CD alignment settings using printer menu as explained in manual from +0.9 to -0.9 with , with no affect ?
This worked perfectly on my old Cannon IP3000 printer
  • 1 more comment
  • Anonymous Dec 22, 2007
    i' ve got the same problem! I can't print on a cd at the very end of it.
  • Harrow1 Jan 01, 2008
    To centre DVD/CD printing on the MP610 refer to "http://pixma.ulmb.com/?p=240 " as stated elsewere
    ie refer to "Cannon CD print alignment" solution
    Use service menu, but adj left/right ( Horz) is "8" press's & up/down( vert) is "9" press's for the Cannon MP610.
    This fixed my problem, printing is now centered .
    at start CDRP = +128, -0167 after adj CDRP = +0015, -0235
    As stated elsewhare, to adj hole size to suit a brand of Disc using cannons dvd/cd printing softeware, "Select paper ," select "new" and set new templete up to required inner & outer size. Save with a suitable name for this type of Disc.
  • Anonymous Mar 21, 2014
    It will not print inside the label part of the address will print at the bottom of the label preceding it.
You need to find the function in service mode: http://pixma.ulmb.com/?p=240
It is a tedious process but it works.
Posted on Dec 25, 2007
Xp-800 cd/dvd printing
The tray is for the DVD or CD itself, not for a label. The printer prints directly on the CD or DVD, you must use ink jet compatible blank disks, the white ones with no printing. You don't need a tray to print the label.
Oct 14, 2014 | Epson Expression Premium XP-800...
Tip
LightScribe Disc Burning
How to burn a LightScribe Disc.
You need to download The Light scribe Template Labeler.
You can get it here. http://www.lightscribe.com/products/index.aspx?id=105
Pick your Platform. ie Windows,Mac,Linux
you can get Designs from here.
http://www.lightscribe.com/ideas/index.aspx?id=2564
Install the Template Labeler
You now need to insert a LightScribe Dsic Into the drive (Lable side down)
Now go to start and left click on the LightScribe Template Labeler Program.
On the first window you'll get an option to do not show again.(your choice)click ok
You are now in the labeler program.
pick a Template
You can download more Templates from a link centered near the top of the screen.
click next at the bottom of the screen.
The next screen you can edit your slected image.click Preview and Print when your done editing.
The next screen you can slect your color of choice and the drive as well as print options.
On the bottom right your estimated burn time will be displayed.
click print near bottom right.
Hope this helped.
on Jun 03, 2010 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Ink won't dry on lightscribe
You need special absorbent coating on the printable DVD's if they are suitable for that. Are you sure you can print on the sort you have usually they are all white. It also must actually say suitable for PC printed labels etc too.
Jun 18, 2010 | Verbatim (95058) 25 Pack 16x DVD-R Storage...
How to print cd covers with HP Photosmart Essential 3 5 i have microsoft office 2010 beta and open office 3.1 installed and some avery standard #8931-face-cd labels nd can not figure out where the tools...
hi Justchuck69.
You can use the software that came with your HP Photosmart all-in-one printer to create CD covers and then print them on the discs. For this to work, the CD must be printable, and you shouldn't use CDs that have their manufacturer, size and speed already printed on them. You must use the latest HP software to create and print the covers. If you can't find the installation disc that came with your printer, download the latest version of the software from HP's Support website.
1 Launch the HP Solution Center that was installed on your computer when you installed the HPsoftware.
2 Click the "View Library" button to open the photo library and then select the folder that contains the images you want to use for your CD cover from the left pane. Click the "Add This Folder" to add the folder to the library. You can only use photos from the library to create the CD cover.
3 Click the "Back" arrow near the top of the window to return to the Welcome screen.
4 Click the "Create" button, choose "Disc Labels," and then click either "Standard CD" if you want to print on a standard CD or "Mini CD" if you want to print on a mini CD. Click "Choose This Format."
5 Choose a design from the list of designs, and then click the "Choose This Design" button.
6 Select the photo or photos you want to print on your CD, and then click the "Add These Photos" button.
7 Use the controls in the Edit Your Disc Label section to zoom, rotate and reposition the photo. Click the text boxes and type or paste some text, if you want to add text to the label. Click "Create" when you're satisfied with the result.
8 Select the HP Photosmart printer from the "Printer" drop-down box, and then ensure the "Standard Sizes" option is selected.
9 Click the "Print" button when you're ready to print the cover on the CD. The "Open CD/DVD Tray" message is displayed on the printer's LCD.
10 Pull the CD/DVD tab below the main tray to remove the CD holder, and then place the disc on the ring of the CD holder with its print-side up. Gently press on the CD until it snaps into place.
11 Lower the CD/DVD tray located just below the control panel, and then insert the CD holder into the tray. The printer starts printing as soon as the white lines on the tray and holder match up.
12 Wait until the printing process is complete, remove the CD holder from the tray, let the ink on the CD dry for a few minutes, and then remove the disc from the holder.
13 Close the CD/DVD tray, and then insert the CD holder back into the storage space.
Tips
  • checkPhoto Creations, the latest software from HP, does not support printing CD labels. HP Photosmart Essential is available for download from HP's FTP website (link in Resources).
  • checkThe back of the HP all-in-one printer must be at least three inches away from the wall or other objects.
  • checkIf you use a small CD, don't forget to flip the holder ring over the disc before you snap the CD holder into place.
  • checkYou can add additional folders to HP Photosmart Essential if you can't find the photos you want to print on the CD.
  • checkYou can bold or italicize the text when you type it, but you can't choose a different font or change the size of the text.
  • checkAlternatively, you can use a free third-party utility to create the CD cover and then print it on the disc.
Warnings
  • closeDon't turn off or unplug the printer from the computer while it prints the CD cover.
  • closeInformation in this article applies to HP Photosmart Essential 3.5. Procedures may vary slightly or significantly with other versions or products.
Ads
CD/DVD Label Software
Download free software to create CD and DVD labels on Windows or a Mac
NCH Software
Start Download
Microsoft™ 64/32 Bit Driver Download Driver Support™ Free Scan
Driver Support.
plus you could read up some more at this link if the above does not work for you.
How to print cd covers with HP Photosmart Essential 3 5 Google Search
Dec 15, 2017 | HP DeskJet F4280 All In One Printer InkJet
Please help me. I haven't printed on a CD with my HP Photosmart D5160 in a while and I either can't remember how to do it, or it doesn't like the new laptop.
I spent a week figuring this answer out. First Do not use the supplied software from HP for this, unless simple text is okay for you. I personally found the software to try to do everything, but nothing well. If you have even a modest image application: Gimp, Photoshop, etc, create a new image at 4.5 inches x 4.5 inches. Set the ppi to 150 at least, 300 for High Quality and create you 'label' there, then go to print.
1. in print dialog box choose 'Preferences'
2. then choose 'printing shortcuts'
3. then choose 'print on CD/DVD' (DVD icon)
(confirm in papersize on right that you are printing on a cd/dvd)
4Then pull down your CD/DVD tray flap on the HP printer and load up a CD to print on. Align it to the arrows, then press print.
As long as the image is 4.5" x 4.5" it will fill the DVD perfectly --especially if you download a 'Mask' template from any printer --which you could google to find one, but it is just to give you an Idea of your 'safe print' zones, and will really come in handy for high quality labels-- don't for get to turn off that 'mask' just before saving--if it's black, or better yet, make it white, then when you save the final image it will create a beautiful white circular edge on the image so that you can better preview and so that you won't waste ink!
Dec 14, 2008 | HP Photosmart D5160 InkJet Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
HP C5580 print settings
Hey! I found this in a review site (can't remember)
"If you use Nero 7 Essentials to print CD/DVD labels, make sure you print just the page for the disc, and under print setup make sure you have CD/DVD 120mm under size and CD/DVD tray from source, then under Preferences set your calibration to -0.185" horizontal, -0.182" vertical, and you'll be golden."
I hope it helps!!
Nov 07, 2008 | Office Equipment & Supplies
Do you know how to print on a CD/DVD?
I have just bought the same printer. if you have found out how to do this then excuse me. It isn't clear cut but basicaly all you do is :-
1/ Make sure you have a blank label stuck on your disc, you can also buy printable discs.
2/ Place the cd onto the cd holder label side up.
3/ Pull the front cover down - where the paper comes out.
4/ If you look carefully further inside where the paper comes out you will see another flap/cover - carefully pull that down.
5/ you will notice 2 little rollers and an arrow next to the right hand roller.
6/ place the cd tray carefully onto the rollers and align the arrows on the tray with th one on the ptinter.
7/ now your set for the software - open the CD Label Print software - click on new - click on image tab - and either image file or if it is from the scanner then select twain capture - if you select image file then either make your own image for the disc or select an appropriat file from the browes button.
I won't go on any more but just experiment, you will soon see how easy it is.
Happy Printing
Oct 24, 2008 | Canon MP610 Photo All-In-One Printer
Roxio Label Creator won't print labels (blank with scissors)
Go to the label creator in your Roxio 6, Click on EDIT, then click on PREFERENCES, go to the DISC tab and unclick the "Print Disc cut Lines" and the "Print Disc outline" boxes. This should fix your problem.
Sep 13, 2008 | Roxio Easy CD & DVD Creator 6...
Dvd and cd printing
This is an easy fix by creating your own template....choose program "cd-labelprint" >> file >> select paper >> new >> (select a name to save as) (select diameter sizes etc) >> OK.
Dec 13, 2007 | Canon MP610 Photo All-In-One Printer
Canon MP610 Photo All-In-One Printer Logo
746 people viewed this question
old marine
old marine
