Question about Haier HWD1000
Hi we have a heller hdw121ss dishwasher the problem is that the washer goes through about three cycles then shorts out our safety switch rgs
Heller ptc55 will not operate on high heat
test the heating element 2) test the switch selector for open or dirty or defective
Jun 19, 2012 | Dishwashers
HOtpoint Fdw 60 goes straight to DEMO mode and refuses to do anything? Any idea?
Try resetting cycle-Push cycle select and cycle start together till you hear a long beep followed by three short beeps.this will cancel previous selection and allow a new program to be selected
Nov 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Can I just take the lid switch off of washer LSQ9110KQ1 and bypass switch by connecting wires
Yes you can short the switch by connecting the two wires allowing the spin cycle to run. This is a safety interlock switch which will apply the brake and stop the spin cycle preventing operator bodily damage to the from pinch points of the tub. The switch is cheap and should be replaced if defective. However, you can temporarily short the switch to use the unit until you obtain the switch. Make sure you turn off the machine if you want to open the lid before the wash cycle is complete. You may have two wires and three connectors on the switch unless one terminal is cut flush to the switch housing. Note the location of the wires on the switch, C= Common Pole N/C= Normally Closed and N/O = Normally Open (you can see the designation on one side of the switch). Your switch should be connected to C and N/O which will make a connection when the lid is closed.
Feb 16, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The dishwasher moter is running when the door is open however no washer is present. dishwasher does not go through a cycle it just keeps running
It seems to be a Safety Switch. Is there any Leak? Check Properly specially into the Base of the Dishwasher. I have seen many Times that could Turn OFF the Safety switch.
Turn off and lean the machine back at 45 degrees, you may see water come out the base. Wait for it to dry out then try again.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 17, 2010 | Siemens 24 in. SL84A302UC Built-in...
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Heller dishwasher fuses electrical circuit during cycle
May be a problem with the element or you may have a build up of water in the base of the dishwasher
Jul 11, 2008 | Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Water filling then emptying again right away
Take the cover off, as you face unit on right side follow the vacum hose to two presure switches. Tap on them lightly with a the handle of screw drive. fix my unit three months ago still working. The problem is the presure switch.
Dec 08, 2007 | Danby 22 in. DDW396 Free-standing...
Replace safety lid switch on kenmore washer#92573210
Hi 1023451,
Pl;ease include the Dishwasher Make and Model so that we can give you precise instructions on how to fix your Dishwasher. I personally an looking forward to helping you. Sorry I cannot help without the make and Model number. So many different kinds of Dishwashers out there, and I am not sure what country you live in to even venture a guess as to what kind of dishwasher it is.
Nov 23, 2007 | Dishwashers
Haier HWD1000 Logo
112 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
