Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Cant find a muffler for 1984 approx. 245 homelite
    President:
  • 2,220 Answers
I tried the Homelite site (no longer available). You probably did too.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
There is at least one old Homey parts source.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a search there are many hits on Homelite saws one matches your model... that you spud? HTH
Lou
Posted on Oct 01, 2009
Need a exsploded view of a oilpump assembly on a 1955 ford customline 272 engine
Your question may have been mis-categorized under Homelite chainsaws. It maybe should be under engines.
Sep 15, 2014 | Homelite 240, 245 Oil Pump Cover
Homelite Chain Saw UT10550 / 18 in. engine starts but will not run at enough speed to cut
It sounds like not enough fuel, air, compression or restricted exaust. Take the muffler off and run it and see if that fixes it. If so clean the muffler and exaust port and your good to go.
Nov 02, 2010 | Homelite Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Manual book for automatic transmisiom volvo 245
i dont think volvo ever produced one because they dont rebuild their transmissions
Jul 02, 2010 | 1984 Volvo 240 Series
Homelite ST-145 oil leaking from muffler
you are right it should be 32:1 for most homelites
Jul 19, 2009 | Garden
Homelite Mighty Lite won't run but a few seconds
Check your muffler to be sure doesn't have a build up of carbon from the oil/gas fuel. This is the problem with 99% of equipment that uses mixed gas. Take the muffler off and see if it runs better without it. If so there is carbon build up in the muffler and muffler port on the engine. Burn the muffler in an open fire for a while to remove the carbon, or burn it with a torch, toss out the screen that's is in most mufflers, (unless of course you live in California where they are required), Scrape out the port with a knife and after the muffler cools on it's own (don't cool with water as you will warp it and not get a good seal) reinstall and see if this solves the problem.
Jun 24, 2009 | Homelite Mighty Lite Lawn Trimmer
St185 Homelite string trimmer starts then dies
I resolved my problem by taking apart the carborator and cleaning it. There were clogged passaged that had stuff come out of them when I used airisol carb cleaner to blow them out. I only had to make one gasket the carb mount gasket which is pretty basic only 5 holes.
It ran for the next 3 hours, ran fantastic!!!!!!
Jun 13, 2009 | Homelite Garden
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
HOMELITE 245 CHAINSAW. IT WILL START UP , BUT WHEN YOU START TO CUT WOOD IT DIES OUT. I HAVE CHANGED THE PLUG , CLEANED THE MUFFLER , AND CLEANED THE AIR FILTER. MEL
check gas tank vent and cap. Adjust carb a small amount ie. back out screw marked L 1/4 turn. If that does not work adjust screw marked "H" 1/4 turn out if no results adjust back to original position and go 1/4 turn farther in.
May 01, 2009 | Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
73 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
