Question about Adobe Photoshop CS for PC
Photoshop automate-batch rename
Working straight from my cameras memory card I renamed a bunch of photos using the "automate-batch- rename"procedure.the photos now were displayed as icons that I have not seen before and could no longer be opened in photoshop either as thumbnails or large pictures ( message given that they were not the right kind of document). I returned to my desk top and tried to open them directly through windows as i often do and again they were unable to be opened. As the photos in question were of value to me I then used a windows option which allowed me to name a program to open the pictures. I had to work on all 73 pictures one at a time but now i can open them but only one at a time using windows fax and picture viewer.. No thumbnails are possible and they are still not recognised by photoshop.Can you tell what i may have done wrong and how i can convert these pictures back to a format that photoshop will recognise. I have used this procedure only once before and it worked OK. I am wondering if this all happened because I selected the same folder in this case the memory card -in which to save the renamed files. Hope you can help and many thanks. denise.
  • 328 Answers
I think Photoshop renamed all pictures using the wrong extension. If you can open images with Windows Fax Viewer, they should work in Photoshop too. Check the extension of the photos, they should be JPEG with a .jpg extension. If not, try to rename them using the .jpg at end of the file name. I would be very surprised if Photoshop cannot recognize photos that Windows can. Tell me if this works because ther is another way but I need to know what extension it is currently.
Posted on Dec 20, 2007
Problems viewing photos
rename your picture or photo (e.g. DSCNxxxx x=numeric value) than download to memory card
Jul 18, 2012 | Nikon CoolPix S6150
I inserted a thumb drive with pictures on it and although they show on the frame, they do not show in the order that I numbered them in
The following advice is not specific to your model, but you have a common problem and the solution I suggest usually works for most makes and models.
Try renaming the files in the order you wish them to play as 001, 002, etc. If you do so without the leading zeroes then on some models of picture frames the filing system gets the images in the wrong order. Note that if you are uploading thousands of images then you may wish to start the numbering at 0001 instead. After renaming the files, re-upload them to the photo frame and you should find that they're OK. Depending upon your host computer's operating sytem you should be able to batch rename the files instead of laboriously renaming and saving each one individually.
Aug 21, 2011 | Quantaray 7-Inch Digital Picture Frame -...
How come when I put my SanDisk 2gig memory chip into my phone, when I try to send pictures to the card it says "cannot rename" and will not work? I have the LG dare
a cannon rename erro means there is a file or folder on the sand disk witch the camera is trying to wrtie to with the same name or file,
1. Move/copy the files off the sand diisk
2. Format the memory with your pc or camera.
This should work let me know ether way if you have questions.
please do rate before you leave, thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 25, 2010 | SanDisk 2GB microSD Memory Card
The Camera will not read my memory card.
The camera likely can't recognize the filenames now that you renamed them. Example: if you camera names the files "DSCF0780", "DSCF0781", etc... and you change it to "Boating at the lake" the camera can not read the filename, therefore the file doesn't exist (as far as the camera knows)
Sep 23, 2009 | Nikon COOLPIX S230 Digital Camera
Lost or Hidden pictures in vivicam 4090
If you are viewing the files on the memory card from the computer, try right clicking on one and click "copy". Then go to the desktop, right click and "paste" to the desktop. Rename it and then try copying and pasting the other one.
Aug 05, 2009 | Cameras
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
Camera Model Wrong
The SD1000 is also known as Digital IXUS 70. If it is showing "Canon IXU DIGITAL 10", it could be because of character limit in the field.
Feb 08, 2009 | Canon PowerShot SD1000 Digital Camera
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Adding prefix
you can use an automation script in photoshop. Do a google search for it. I can't remember how to do it off hand! ALternatively, you can do a batch rename using infranview. Again, google is your friend.
Feb 06, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Adobe Photoshop CS for PC Logo
70 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
