Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer making a thumping sound when engaged
    President:
  • 267 Answers
HI, rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise,
thank you for using fixya,rate my answer
vijay
Posted on Oct 01, 2009
Dryer runs and drys but makes a thump soud every revolution "like a tennis ball"
Check the belt that is on the drum. It sounds like it may have a chunk broken off of it and you may need to replace it.
Aug 09, 2014 | Maytag MDE9700AYM Electric Dryer
Maytag dryer tha-thumps
It is safe to use the dryer, I don't see any foreseen future to other parts. But the idler definately is flat(tening). It should be replaced asap.
May 24, 2012 | Maytag Dryers
My Dryer makes a thumping sound when rotating even when rotated and there no power. MED6500TQ
your belt may need to be replaced. could have a crack or missing chunk out of it making it bump as it rides over the pully.
Apr 05, 2010 | Maytag MED5600TQ Electric Dryer
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
My new dryer thumps every revolution
Flat spots on the support rollers from sitting in storage will make a thump. So will heavy wet clothes if they are not spun dry enough from the washer. This may lessen as the unit is used but since it is in warranty a service call to rule out major problems is in order.
Eric
Jun 17, 2009 | Maytag MDE9206 Dryer
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
