No picture,steady lamp light - Televison & Video
    Genius:
  • 1,112 Answers
Replace Lamp Assembly
Posted on Oct 01, 2009
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
No sound, no picture.
Hitachi DLP Television Bulb
Most likely a bad lamp. I would replace it first to make sure.
Sep 06, 2015 | Hitachi Televison & Video
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
No picture when ,steady red light
Hello:
It sounds like you might have a defective lamp. Please feel free to give us a call at 866-764-5822 and we would be happy to help you troubleshoot the problem over the telephone. You can also email us at sales@dlplampsource.com.
Best Regards
Dan
DLP Lamps Projector Lamps Specialty Lighting
Apr 02, 2014 | Mitsubishi WD-60737 TV
I have a wd65733....When I turn the set on, I get a picture then about 30 seconds later it will shut down giving me a steady orange light
CK Lamp and Lamp Fan, Mats has Lamps for $99.00
other companys want 273.00 1-800-628-1118
Encompass Parts Distribution has Free service Manual for this Model, you can print out online.
Sep 13, 2009 | Mitsubishi WD-65733 65" HDTV
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
Lamp light is steady yellow. TV works fine otherwise.
Order another lamp and have it on standby as the steady yellow light is telling you that the lamp has outlasted the normal rated useage hours so your lamp will fail without warning at any time.
May 13, 2008 | Mitsubishi WD-52628 52" Projection HDTV
No picture
If the red light stays steady, and the green light blinks 9 times then repeats, it is most likely the lamp #23311083A about $200. Otherwise, if a cooling fan is not working, it could possibly cause a shutdown problem. You can't always tell a bulb is bad by looking at it. Another possibility is the lamp ballast, but I would try a new bulb first.
Feb 10, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Electro Med Services...
