Question about Plumbing
Have a Moen Monticello Moentrol Tub & Shower Faucet T3132. Mixer not set up properly - turn the handle left, all hot. Turn the handle right, all cold. Shutoff in the middle. Ne'er the two (hot & cold) shall meet. Help!
  • Anonymous Mar 24, 2014
    cant adjust flick mixer to right temp in the shower
  • 129 Answers
Try taking the handle off and turning it 180 degrees, and then put handle back on. Dont laugh it could work.
Posted on Oct 01, 2009
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
I jhave in my showers the Moen and One handle tub and shower faucet, model # T3132. When I turn it on in the showers, there is no hot water... in both it gives me only cold water... even if I turn the...
As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced. On both sides of the valve are 2 smaller screws. these are the water shut off valves. turn off the water and remove the larger screw fitting. remove spool and replace. Hope this helps.
Dec 21, 2010 | Moen & One Handle Tub & Shower Faucet
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
When you turn to hot it doesn't come out. Cold does.
Assuming that you have hot water at other faucets the problem could be a varnish buildup in the cartridge. After shutting off the hot and cold water either by turning off the main or at the faucet stops (if equipped), remove the cartridge and soak it in white vinegar to break up the varnish. You can clean it up with an old toothbrush and make sure that it is working. It should rattle when you shake it. new cartridges are not very expensive so you can just buy a replacement at any home center as well. If you are the original owner of the faucet Moen will send you a free replacement cartridge if you call them.
May 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
HOW DO I FIX A LEAKING FAUCET ON A MOEN L3189
you need to remove the cartridge behind the handle. If it is dripping from the spout or shower head.
If you pull the handle to turn it on it is called a moentrol valve and take a number 1225 cartridge....it it just turns to turn on it is called a posi-temp valve and takes a 1222 cartridge.
Oct 20, 2009 | Moen & One Handle Tub & Shower Faucet
Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Plumbing Logo
212 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
