Question about Kenmore Dryers
I have a kenmore model #86863800 which no longer starts when pressing the start button.The timer on the dial still works fine (you can hear it going) but the dryer does not start. The button switch for the door is working fine (you can hear it click when you press it in and release it) The little switch mechanism behind the start button has some browning around the points on the plexiglass cover , but seems to be just fine (no burnt parts etc...) when bypassed by connecting the 2 wires black & white together for an instant , still nothing happens. I have looked at all other connections of wires and can find no burning or scorching visible. To be clear , when the button is pushed or bypassed , NOTHING happens , no buzzing no clicking , just NOTHING.
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
jsrock516
  • 5911 Answers
SOURCE: My non-starting dryer
Make sure you perform all checks with the dryer UNPLUGGED.
Double check the thermal fuse just to be sure. It will be located on the air blower housing and should be a white plastic component with two wires connected to it. It should read a short if good. I could be mistaken, but I believe the drum light will still come on with the thermal fuse blown. If I led you astray in my write up, I do apologize. All dryers are not configured the same.
If the thermal fuse is good, pull the connector from the drive motor and inspect it. I have found where these connectors look like they are tight, but actually aren't, causing the connector and wires to burn. If the connector checks good, you have a couple of options. You could have a defective motor. Take a resistance check across the blue wire and violet wire on the motor. This should be your start winding. Resistance should be between 2.4 to 3.8 ohms. If it reads anything higher than 4 ohms, it's recommended that you replace it. If the motor is okay you may have a defective belt switch and/or centrifugal switch. I'm not sure how your dryer is configured. I will need the COMPLETE model number (located around the door opening) to be sure.
Before I can give you further advice about troubleshooting or replacing parts, I need to be sure of what you find. Please post back and let me know.
Posted on May 29, 2008
rickzilla
  • 706 Answers
SOURCE: Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Posted on Aug 14, 2008
AlmostBob
  • 550 Answers
SOURCE: Push to Start switch does not Start Kenmore Elite Dryer Mod # 11065944401
A likely cause is failure of the relay.
the start switch provides a current to energise a relay,
the relay latches open (draws energize current from switched circuit) until current path is broken by the timer or door switches.
if the wires have come off the relay(happens) or the coil of the relay has failed, there will be no start.
With plug pulled
trace the wires from the start switch, to the first device, looks like this 8fc4980.jpgmay be opaque. if any of the wires have come off refit them and retry start.
relay diagram looks like this 5a14628.gif test with meter for conduct between terminals labelled 85 86 (or Coil in other labelling standard),
or take to appliance parts store, can test and provide replacement on site.
Appliance part store will likely provide part labelled whirlpool, not a problem all the small parts are interchangeable
NOTE dryer relay may have up to 8 terminals,
2 for coil
3 (open close common) for each phase
Posted on Oct 30, 2008
  • 686 Answers
SOURCE: Kitchen aid electric dryer won't start. The door
change your thermal fuse
Posted on Mar 12, 2009
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
My HB1116R TIMER STOPS RUNNING ON OFF WORKS FINE thank you in advance if i tap on housing i can hear timer starting for a few seconds
If the timer dial will not push the tripper past the on-off lever, or if dial is no longer rotating, or is rotating slow, then clock motor has gone bad.
There are no replacement clock modules for HB series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
You can set timer to override and plug HB into another plug-in timer
Intermatic site no longer shows HB series outdoor timers except for HB8800.
http://www.intermatic.com/products/ec%204%20layer/plug%20in%20timers/plug%20in%20timers/plug%20in%20timers.aspx
Amazon still sells HB1116R
Jul 07, 2011 | RTO Intermatic HB1116R Power Stake With...
Kenmore dryer #86863800 suddenly stopped heating. Having trouble figuring which thermostat or element should be replaced. This dryer has no high/low setting. Only more dry or less dry. One big knob to set...
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Kenmore Elite HE4 Electric Dryer
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Aug 27, 2009 | Kenmore Kitchen Ranges
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Jan 05, 2009 | Kenmore 659 Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
