I have ir2230 this machine convert to ir3530 its possible pls tell me
I have an error code E000024-001,Canon ir 3530
Posted on Oct 22, 2009
    Sniper:
  • 153 Answers
What do you think!!!!!!
Posted on Oct 02, 2009
Where are fixed toner sensor in iR2230 machine, give me image or video
Open the front door and side door and pull out the developing unit. Just under the it is the toner sensor unit.
Oct 10, 2014 | Canon Super G3 Fax Board for IR2230 Copier...
Haw to find the all night power suply in ir3530
There is No such power supply called "all night power supply". Have you tried to adjust the display contrast on the control panel????/
Jan 13, 2013 | Canon IMAGERUNNER 3530 Copier
My IR2230 displays E000110-0001, i have replaced the laser unit but the error code still comes. Pls help- Sam.
the only thing that remains for you, that you can check/replace/reconnect is DC controller.
Hope that helps!
Jun 10, 2011 | Canon imageRUNNER 1630 Copier
Im looking for service manual for canon ir2870 copier
Here: http://www.smpcshop.com/Canon-iR2230-iR2270-iR2870-iR3530-iR3570-iR4570-Service-Manual.html
Dec 20, 2010 | Canon Office Equipment & Supplies
Hi, How do I remove the optional hard drive on a Canon IR2230 without the machine generating a code E602-0411
The Hard Drive is not a option..... You need it to use the copier..... The operations of the copier are on the hard drive, it is like the hd on your computer. The error code you are getting is telling you that the hd is not working...
Nov 23, 2010 | Canon IMAGERUNNER 2230 Copier
I AM ATTEMPTING TO USE THE SCANNER FUNCTION ON A CANON IR2230
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
Jan 01, 2010 | Canon IMAGERUNNER 2230 Copier
Canon ir3530
As far as I know this machine comes fitted with a network adapter already and all that needs to be done is for you to purchase the license (this comes as part of the PCL or PS Print Kit) to enable the printing feature. I know with some models an additional memory DIMM also needs to be installed. I'm not sure if this is one of those models, but in the event that it is, the DIMM is also supplied with the print kit and it is accompanied by a complete set of installation instructions
Sep 23, 2008 | Canon imageRUNNER C3200 Copier
464 people viewed this question
k24674
jasbo
jasbo
