Question about Motorola Mobility RAZR V3
Help! stuck in "No Service"
I got this brand new (in-box) Razr V3 phone from an old friend, but I'm not sure where he got it. I took it to my T-Mobile dealer, because when when I put in my SIM card it says "Searching for Network" for about 30 seconds and it can't find any, it just says "No Service". They told me it was unlocked but they couldn't figure out why it wasn't working. They had me talk to technical support for about a 45 minutes. They couldn't figure it out either. They had me call Motorola where they told me the phone was manufactured for somewhere in Europe (Germany maybe), and that it was out of warranty. They had me do a master reset but it didn't do anything. They suggested I go to their website and update the software. I went through all the trouble and did it all, but the Razr still can't find the network.
PLEASE HELP!!!!!!! What else can I do? ANY IDEAS?
Motorola's software says this about the phone:
IMEI Number: 3594180XXXXXXXX
Model Number: RAZR V3
Operator: andere Netzwerkbetreiber - autre opã©rateur CH
    Brigadier General:
  • 7,752 Answers
Re: Help! stuck in "No Service"
Okay what you have to do, cause to me it sounds like your internatl antenna needs to be take it to a mobile repair center and have them replace the antenna that will correct your problem...i guarantee that to you.....
Posted on Dec 21, 2007
0 characters
3 Points
My daughter was given motorola razv3 the vodafone sim card is very old and says it;s not registered, will a new vodaphone sim cure it.and she wants to have it unlocked to use o2 sim. HELP PLEASE
ya sure you can unlock your motorola mobile and use it with any network ......
With the help of the codes you can unlock your mobile,
Get the unlock code for your Motorola Razr V3 model mobile from this site , here get the unlock code for your mobile along with easy instructions and methods.........
Nov 14, 2011 | Motorola Mobility RAZR V3
Unlock razr v3
Which Country Network Lock now?
You can get the Unlock code and Unlock Instructions at
follow the Instructions and Unlock it step by step:
Motorola RAZR V3 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola RAZR V3 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola RAZR V3 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola RAZR V3 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola RAZR V3 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola RAZR V3 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Mar 17, 2011 | Motorola Mobility RAZR V3
I need a subsidy code for a Motorola V3 razr
which one is locked? the phone or your sim?
your friend's mobile phone might be sim-locked into a particular network only. T-mobile phones uses only sims that are T-mobile. If you inserted an ATT sim into a T-mobile phone, it is expected to react that way. That is also why, ATT told you to call T Mobile because it was not the responsibility of ATT if their sim won't work into a T-mobile phone (if that was really the case).
that was just a hint. the initial remedy would be is, insert a T-mobile sim into the T-mobile phone first and also confirm to your friend if it was a sim-locked phone.
subsidy codes are exclusively from the company. it's very, very, very (nth power) seldom that one can be provided online (w/c is safe and reliable). so please hope that either my suggestion would work or they will still provide the subsidy code because the case might be beyond the warranty requirements.
Feb 07, 2009 | Motorola Mobility RAZR V3
Change Contact Number, on Moto RAZR V3, Tata CDMA
dat old no is working???if not den dey can direcltly transfr on dis mobile..they hve to do programming for that......
if dis cant help u plz visiti service center of motorola...
Jan 17, 2009 | Motorola Mobility RAZR V3
Motorola RAZR V3, Ii hangs when typing SMS.
the firmware needs to be reflash on the phone to correct this issue...take the phone to a mobile service center and have them fix it for you.
Dec 14, 2008 | Motorola Mobility RAZR V3
Help Unlocking A AT&T Razr, So I Can Use With T-Mobile.
o teclado eu digito o numero no *8486 aonde pede o CPF só que escrevo meu CPF e ele apareçe como não digitado ou seja não esta funcionando meu V3 é V3 razr
Sep 03, 2008 | Motorola Mobility RAZR V3
Free unlocking or subsidy code for mobile phones
I have motorola rizr z3 mobile.I got the information of mobile unlocking from this
It's having the motorola razr v3 also.This is a site helpful for you.The code is also an cheap cost.
Aug 25, 2008 | Motorola Mobility RAZR V3
Phone is on but is frozen on the first page
you need to have you mobile firmware stop it from freezing...take the phone to a mobile service center and have them flash it for you.
Feb 18, 2008 | Motorola Mobility RAZR V3
Razr v3 will not turn on
try changing the battery.....if that does not help you may have to get the mobile service or flash from a mobile tech....but if the phone is 3days old, just take it back to the provider and have them give you a new one.
Dec 31, 2007 | Motorola Mobility RAZR V3
Motorola V3 RAZR
since it is new you can return it to the store you purchased it. it is covered by warranty. or maybe your batt is not yet charged...
if everything is fine, then have your phone repaired to a trusted service center coz usually the phone software is corrupted. have your phone reprogrammed...
Oct 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
