Question about Cameras
Most of my canon 650 IS functions are locked.
The camera model is A650 IS (image stabilizer). the problem is as soon as the camera is switched on its automatically aims, as if i was pressing the shoot button half way down.i can take pictures though. however i cannot zoom in or out. when i want to view the pics I've taken i cannot scroll through the pics n i cannot magnify the pics.in fact none of the buttons are working except the round dial to change the different picture taking options (eg changing from ''auto'' to ''portrait'') and the shoot button.
  • jahtow Dec 15, 2009
    SOLUTION! hi.ive discovered the solution of my problem. quite a simple solution, but not obvious at the time.the shoot button did not fully extend up to its orginal position, therefore disabling the functions mentioned in my original problem. my solution was to simply clean the area between the button and the casing of the camera. i used a needle since it was the thinist, strongest and sharpest object i could find. since then my camera's been working fine. i hope this solution helps other folks having the same/ similar problem.
SOURCE: Canon Powershot A75 problems
Having read on a few sites about loose ribbon wires causing problems and having this same problem. I decide to take the camera apart. Taking all the screws out and fidling with the "wires" connecting the zoom control and the photo type selector and the main circ board. I also cleaned the connector from the picture type selector. Then put it all back together the camera works fine again. NOTES... lots of small screws with varying lengths make sure you know where they come from. Took about 1 hour to do.Put back in the order you take apart or the back will not go back on.. Good luck have just saved myself a fortune
Posted on Feb 04, 2007
  • 4 Answers
SOURCE: My camera will not take a picture unless lock button is held
Had this problem two weeks ago. On the road to recovery, changing the purpose of the function button seems to have helped me - <Menu>, <Set-up1>, <Controls>, <Func.> Change chosen option away from the top one (User Setting). I found the third one down with the flash symbol least confusing. Then <Set> and <Menu> button to escape from the menus.
Having done all this the camera will take pictures again without pressing the lock button. However, I'm not convinced the func. button works as described in the manual. Hope this helps?
Posted on Feb 10, 2008
iwctoys
  • 126 Answers
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Posted on Jul 02, 2009
  • 244 Answers
SOURCE: problem viewing pics i've taken/deleting old pics/using zoom
keypad failure is common with this camera. the ribbon connecting this to the board has 2 folds in it that split over time.
Replacement is the only solution
Posted on Aug 30, 2009
Code
  • 33 Answers
SOURCE: My Cannon Powershot SD1000 LCD screen does not work.
Has the screen been cracked/damaged? Was your camera dropped in any liquid? It's worth it to try having the LCD screen replaced, as it's quite affordable. If there is liquid damage near the LCD input inside the camera that would be another issue that would be solved by replacing those main boards.
In an ideal situation it would be just that the backlight cable wiggled itself out of its input (I'm assuming the screen doesn't light up anymore), which is something you could look at yourself if you're comfortable taking your camera apart. I wish you luck =)
Posted on Sep 09, 2009
My canon 5x optical zoom 16.0 is telling me Memory card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 24, 2014 | Canon PowerShot A3400 IS 16.0 MP Digital...
Card is locked
There is a tiny switch on the memory card that is used to lock to prevent accidental erasure. Make sure that this small lever on the side of the SD card is pushed to unlock.
Apr 06, 2011 | Canon PowerShot A650 IS Digital Camera
How to fix image stabilizer problem ?
If the subject moves, no image stabilizer is going to help.
Mar 06, 2010 | Canon PowerShot SX20 IS Digital Camera
Mode switch has broken off and the camera screen says no image
it probably remained locked on the viewer and there are no images capture stored into the camera ..that's why it says that ....and it must be a way to restore the function of that button cause no matter if you lock it permanently into the the shooting mode its still a issue of getting pics out of it ....most cameras have to be on viewing mode when are plugged on the data cable ...but ..if you can open it and switch it on the mode that allow you to take pictures...you can always get the pictures from the SD card directly via an card reader ...adapter ( USB) that cost only a few dollars...
Aug 07, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Reduce photo size
If you want to take lower resolution photos, it's pretty simple.
Go into the Menu on your camera, and look for "Quality".
Canon does "Large" "Medium" or "Small", if you change to "Small", you'll fit more images on your memory card.
However, "small" will make the photos not look as good as "large", keep that in mind.
Mar 17, 2009 | Canon PowerShot A650 IS Digital Camera
Image stabilizer stopped working on Canon 70-300mm lens
Taken that you made sure that the IS switch was on, on the lens, yes you have to find a camera repair shop to get it fixed.
The best shops are authorized Canon repair shops. You can call Canon support, and they should be able to give you advice on what shop to send the lens to.
I hope this helped!
/Chris
Oct 31, 2008 | Canon Cameras
Image Stablization not functioning
Image stabilization cannot correct for movement of the subject (fan). Image stabilization only corrects for movement of the camera/photographer. If you take a picture of the ceiling fan with the flash turned on, or set the ISO to a higher number, you will see that the fan is less blurred because you have increased the shutter speed.
May 01, 2008 | Canon PowerShot A710 IS Digital Camera
Image Stabilization not functioning
The stabilization is not for moving objects! To freeze a picture of a moving object, you need to raise the shutter speed and open the apature accordingly. Refer to the light metering in the camera for proper exposure. For faster speed, you really need more light.
The stabilization is for when you hold the camera. It helps prevent camera movements by the photographer to show in the pictures.
Just take care that the image stabilization has its limits.
Jerry G.
Image download issues-Canon A650 & Windows Vista
oh my GOD Same problem with Sony Cyber Shot DSC-W35 !!! photos splitted into 3 parts vertically or horizontally, i don't know why
Dec 26, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
