Question about GPS
I have an AirMap 600c GPS which causes bad interference on my airplane radio when a power cord is used to a cigar lighter outlet on the GPS
  • 1 more comment
  • wesfelty Oct 01, 2009
    I?ve been in electronics since 1955. At the age of 13, I was a radio/TV repairman. I built my first computer in 1958. I have a BS and MS degree in Physics which included a lot of electronics. I taught Physics and Electronics for 38 years. I have never in my life received as stupid an answer as I did from your ?GURU?. This sounds like an answer that I would expect from a 30 year ago AI program like Lisa. You charge people for answers like this? That is fraud! I expected to get an answer from a Lowrance AirMap tech.
    In case you can?t figurer it out ?
    ?Put in a resistor or capacitor? ? just any old resistor or capacitor? A resistor would do nothing for RF interference and a capacitor in series with a power lead. A capacitor is an AC not a DC device. It would act as an open circuit. That would ?fix the problem? by disconnecting the power lead. A capacitor can also be used to store power as with a photoflash, but that is in parallel, not serial and not applicable here.
    ?a fuse? ? that should act as if it weren?t even there unless too much current went through the power lead, also not applicable here.
    ?to lower the frequency amps? ? What the heck? This doesn?t even raise to the level of ?techno babble?. What the heck is that? ?Frequency? and ?amps? have nothing to do with each other.
    I?ve receive better ?answers? from ?computer service? people in India who didn?t speak English on computer questions. This ?answer? was nothing more than a half dozen electronic terms strung together.
    What is this? I need to cut another hole in my instrument panel? And shorter cords, not longer cords are recommended to lower interference! If the power cord is acting as an antenna, it should be shorter.
    I have relocated the radio as far as possible from the GPS with no improvement.
    What is this? These "solutions" are silly at best. Is there anyone who knows anything?
    Thanks for the reply. Yous was the only reply that made any sense. I can't believe the incompetence of the other two answers. "Put a capacitor" in series in the power lead to reduce the frequency! The capacitor would just cause an open circuit and what is the frequency of DC? Zero And, the other response to increase the length of the power cord, you try to reduce interference with shorter cords. I have never seen such incompetence passing itself as "guru".
    -Wes
  • 691 Answers
I have the same air-map 600c which I had it upgrade from an old model 500. I don't have any problems with mine but 4 of my friends also has the 600c although 2 out of 4 of my flying Buddy's did have the same problems with theirs so they return the unit and got a new one, One of them his problems is no longer an issue although the others still have the same problems. we all have the same radios in our aircraft so we cant figure it why some cause interference and some don't. See if you can take the unit back and do an exchange that might solved the problems if not, that something I doubt we going to solve beside changing AC radio. good luck
Posted on Oct 01, 2009
    President:
  • 1,884 Answers
Try shifting the cigar lighter outlet away from the radio and use a longer cord to charge the GPS.
  • 11,896 Answers
You may be able to cut a piece of the wiring out and install a or resistor or capacitor or fuse to lower the frequency amps that is causing the interference.
  • Nate Stansfield
    Nate Stansfield Oct 01, 2009
    The longer the wire the better.
    I am telling you to put a capacitor or resistor in the wiring from the power outlet to lower the frequency. The farthest away the components are from power source, the better.
Ciger lighter position 41 keeps blowing 47 ok
AUX PWR Fuse #41
20A
Auxiliary Power Outlets - this not Cigar lighter ,the power outlet is bad. replace it or short to ground in wiring.
CIGAR Fuse #47
15A
Data Link Connector, Cigar Lighter
the power
Nov 08, 2015 | 2000 Chevrolet Silverado
What will cause my radio,clock and power outlet not to work?
Let me ask a few questions: The items mentioned, radio, clock and power outlet...are these the only items not working? does the instrument panel light? Also , does the cigar lighter work? Lastly check fuse # 7(40A) in the battery junction box
Jul 03, 2014 | 2003 Ford Focus
Cobra xrs 9955
The simplest advice is to check the power connections. If connected to the cigar lighter / power outlet of the car, remove & reinsert the plug into the outlet.
Still no luck?
Try powering up the detector in another vehicle's cigar lighter / power jack. If it works - try again in your car. The problem is not with the detector, but rather with the installation in your car.
If wired directly to an accessory terminal or other place in the car, check the connection(s) and cable for damage.
If you can't try it in another car, try plugging another device into the outlet to see if it works or check and replace any blown fuse for the outlet. You should consult your car's owner's manual for the fuse box location - and the location and amp rating of the fuse for the outlet.
Check the power cord. Make sure the cord is fully inserted into the detector - not hanging in the jack. The opposite end - that goes into the cigar lighter / power outlet *may* have a built in fuse in the tip. You should check to see if the center tip of the plug unscrews to provide access to the fuse. If it does, replace any blown fuse with the same type and amp rating and try again.
If you were unable to check in another car and you are still unable to power up the detector, there may be an internal problem with detector itself. In this case, contact the manufacturer for additional help.
Jun 06, 2013 | Vehicle Parts & Accessories
Gps 1412 will not charge
Have you check the voltage output on your power/charger cord? It's easy to test if you know how to use a multi-tester or take it to a small electronics shop like a Radio Shack.
If there is no voltage output from the charger, then simply replace the cord. I have found that those charging cords can break real easily but it's hard to physically see any damage.
Otherwise, if you've already tried a new charger, you may need to send your GPS in for service.
Mar 31, 2012 | Magellan RoadMate 1412 Car GPS Receiver
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Lowrance AirMap 600C won't lock on satellites
Reset the AirMap 600:
1. Turn unit off
2. Press and hold PAGES and PWR until you get the "warning, do not rely..." message and then release the buttons.
If it still won't acquire position, install the latest update from http://www.lowrance.com/en/Products/Aviation/AirMap-600C/Downloads/AirMap-600C-Software-Update/.
If it still won't acquire, and it has a clear, unobstructed view of the sky, and the batteries are good, there is a malfunction and it will require service or replacement.
Jul 13, 2009 | Lowrance Iway 500c GPS Receiver
HOW TO REMOVE 12 VOLT OUTLET
The outside ring screws out of the socket to remove it. I always just stick 2 of my fingers into the socket and twist it.
Jan 30, 2009 | 2004 Ford F150
Lowrance 100 works lowrance 500 dosen't [dropped] swap chip?
You cannot use a chip from the AirMap 500 in an AirMap 100. The AirMap 100 is not compatible with the mapping used with the AirMap 500 and the AirMap 100 does not have a memory card slot.
I suggest you use the AirMap 100 while you think about getting the AirMap 2000 or some other newer aviation GPS unit.
Jan 04, 2009 | Lowrance 5300C GPS Receiver
I have Mitsubishi eclipse '98 GS.Cigaret lighter just stopped working. Checked the fused and replaced but it's still doesn't work. I was using a portable compressor to pump some air in my tire. I need it...
so you replaced a blown fuse to the cigar lighter and it still dosent work?.. then the wiring was compromised before the fuse blew..you need to repair bad wiring to cigar lighter and/or lighter itself internally melted /failed due to your air pump asking for more electricity than the cigar lighter could deliver..once repaired do not use the air pump there again ..good luck
Dec 02, 2008 | Mitsubishi Eclipse Cars & Trucks
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
