Question about Jenn-Air JCD2389G Side by Side Refrigerator
Buzzing and clicking sound every few minutes
My five year-old referigerator is making a buzzing clicking sound every few minutes. What could be causing this problem?
    New Friend:
Jenn air model JFC2089HTB making a loud buzzing noise every few minutes?
Posted on Jul 05, 2013
    Habit-Forming:
  • 41 Answers
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Posted on Oct 01, 2009
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
tborn6
  • 700 Answers
SOURCE: freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Posted on Dec 26, 2008
philbran
  • 242 Answers
SOURCE: Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Posted on Jan 07, 2009
  • 400 Answers
SOURCE: JBR2086HES - Jenn-Air
If it was buzzing then click, the click would mean that the thermal overload has activated. This would happen if the compressor is drawing high amperage due to a breakdown of insulation on one of the starter or run windings. What he says is very possible.
Posted on Mar 05, 2009
  • 219 Answers
SOURCE: Clicking noise from JCD2295HES side-by-side refrigerator
sounds like a compressor relay check with maytag mightr be one of the recall ones
Posted on Mar 19, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
No picture.... makes a buzzing / small bell sound on and off...it has sound but after a minute it turns itself off.
This is a projection tv correct?Yes?The old projection lamp has not been replaced like 1 1/2 or 2 years?Tv in used daily like 4 or 5 hours everydays?Yes?Tv make buzzing sound and bell sound on and off.The tv on the frame the word "LAMP" the LED light indication it is flashing or stay on lit?Yes?Then the tv projection lamp life have ended,tv require a new projection lamp.
Aug 10, 2011 | Mitsubishi WD-60735 Projection Television
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
I have a Jenn Air refrigerator and it is making a loud buzzing noise every few minutes...fridge and freezer are not as cold...what could it be?
sounds like the overload relay assy trying to start your compressor, usuallya sign of a bad compressor.. you can try to replace the overload relay, but if its under five years you should have a full manufactue warr on the compressor (comes with new overload relay)
Apr 04, 2008 | Refrigerators
Side by Side Frigidaire Galleria Freezer is making buzzing sound, on and off every few minutes. Freezer is not working, water coming out of ice maker. I removed toe kick plate and removed alot of *** hair,...
clean the heck out of the coils underneath and give the manufacture a call, you should be covered by a 5 yr warr on your compressor(reason i say clean it is if they come see it clogged they'll blame you and deny your warr.stating cust abuse
Mar 10, 2008 | Refrigerators
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Jenn-Air JCD2389G Side by Side Refrigerator Logo
359 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
