Question about Sony Cyber-Shot DSC-P72 Digital Camera
MY CAMERA WORKS FINE ITS LIKE BRAN NEW HOWEVER ITS MISSING THE MEMORY PRO CARD, HOW MUCH IS A MEMORY CARD? AND I NEED A MANUAL ITS A SONY CYBERSHOT DSC-P72
    President:
  • 267 Answers
this is the manual
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscp72_question.html?qid=4266
memory card will cost 30-50$
thank you for using fixya,rate my answer
vijay
Posted on Oct 01, 2009
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
New sony cybershot camera with a sony memory stick
Hook one end to the computer the other to the camera, turn the camera to review picture mode
Open up my computer, look at the external drives, you should see the camera after a minute or so.
Click and drag
Mar 06, 2010 | Video Cameras
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Wont access memory card
i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
Dec 28, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Can't access pictures taken
If you can't access the memory card even with a card reader...your camera is working fine...the problem is ith your memory card (internal problem)...if your warranty is not finished sony will replace that to a new one
PLEASE RATE ME ( FIXYA )................................
May 26, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
P71
Does your camera works fine with the previous memory card?
Sep 03, 2007 | Sony Cyber-Shot DSC-P71 Digital Camera
Sony Cyber-Shot DSC-P72 Digital Camera Logo
95 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
