Question about Lenovo 3000 N100 Notebook
On power on I am not seeing the display
Laptop was working fine.I shutdown the laptop.On restarted the laptop by power on button.I see the power on indicator on the panel but not seeing any display on the monitor.
  • 93 Answers
Hi frnd..
just remove the battrey and unplug the ac adapter and press hold the power button for 30 seconds.. and then plug in the battery and AC adpapter and then start tje system it will start.. take care..
Posted on Oct 01, 2009
  • sriniknight Oct 01, 2009
    Hi frnd..
  • 11,896 Answers
Either power supply is faulty or motherboard is fried. You can test power supply wires to motherboard with a voltmeter. Should be 12-13.5 volts. To high or very low voltage is bad and can fry video part of motherboard
GETTING THE DISPLAY TO WORK
try holding down power button for thirty seconds on laptop.
once you think it is off remove power lead and remove battery.
place battery back in and power cord
Try pressing power button on laptop
see if anything is displayed on screen at power up
see if operating system loads correctly
suspect laptop locked up and needing a full shutdown
Jul 30, 2016 | Computers & Internet
My laptop won't start up it turns on but then nothing
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot.
If it boots, then shutdown, add battery and restart.
The laptop's screen display may remain black when there is a corrupted graphics driver, or a problem with the LCD display's back light. (Try tilting the screen to 30 degrees and see what happens.)
It could possibly be that your outputting to the wrong screen - most laptops have a "Fn" button that can be pressed in conjunction with a little screen on the keyboard to switch to either internal display or external (say F1 or F2).
Mar 04, 2015 | Computers & Internet
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
Laptop is run and start but no display
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
Dell e1505 won't power off
Check or Change the PSU or charger.
Jun 28, 2012 | Computers & Internet
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
No display after restart
bro I am having the same problem!! after searching I found that the pc gets display on my case if I remove power cord and press the power button (and holds on) of pc like 30 seconds and then reconnect the power cord and powers on!! this is how I get back display after restarting pc.
Feb 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
My laptop restarts automatically after shutdown
i might have to reformat your computer and if that doesnt work then take it mack to the manufacture and see what they can do about it sorry.
please rate my help to you.
thank you.
Apr 22, 2009 | Computers & Internet
Will not power up, no fans, post code or display
when you say you press the reset button you mean the power button right?
I assume you just press it and pc restarts...
instead bootup to as far as you can get then press and hold power button until pc turns off then reboot ..you should now be able to access the point where it says windows was shutdown incorrectly or interrupted options to restart normal or last good config etc..
if it doesnt you may need to reinstall windows
Jan 13, 2009 | HP NX9010 Notebook
Lenovo 3000 N100 Notebook Logo
122 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
