Question about Galaxy Computers & Internet
Wiring product came with wires that m old one didnt have. where do these new wires connect?
  • Lavell Turner
    Lavell Turner May 11, 2010
    Hello what brand is the new Card, most new video cards come with DVI and Svideo connetors.
    Scholar:
  • 89 Answers
Having the product Model would help... Im assuming they gave you either a secondary power connector or an S-Video cable for connecting to a TV. Cant be sure though, try providing more information...
Posted on Oct 01, 2009
Can I just cut the black wires coming out of old switch and connect with wire nuts to black wires of new switch? And cap off the ground wire from new switch since no ground on old switch?
You could do that but it would not be up to the electrical code requirements. Take the old one out and remove the wire nuts and put the new one in. There should be a ground wire stuffed in the box somewhere. Unless the house is really old. You connect the ground wire to the bare ones in the box.
Nov 20, 2016 | Lutron Electrical Supplies
Hotpoint stove timer replacement
what color wires are on the new timer?
Apr 07, 2008 | Ovens
Were can i get harness for a bv9990 boss stereo or at least the diagram for the wiring so i could do harness myself
You might be able to get an adapter that would connect your Boss unit to your new vehicle's wiring. Check with Crutchfield to identify the correct adapter.
Dec 26, 2014 | Boss Car Audio & Video
I'm installing a ceiling fan w/lights. The new remote wall module has 2 black wires ("to motor" & "A/C in L"), but the old flip switch has 2 black wires (both on same side, 1 on screw and the other through...
Add a comment with more information:
1) Brand and model number of fan and remote so expert can access product manual. Without product manual, we're guessing. If product manual has a phone number call it.
2) Attach clear in-focus photo of existing switch with all wires for best possible guess.
3) get a tester and find which wire inside the box is hot. Turn off switch and test each black wire to bare ground wire.
Gene
h
Sep 16, 2013 | Intermatic Inc. ST01C Digital In-Wall...
Motion sensor light
Just ignore the fact the new device does not have white neutral. While old device has neutral
Difference: The new device is rated for incandescent only, while the old device was rated all type of lights including cfl etc.
Copy following link for wiring illustrations
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
Check manual for product rating. You might want to return device and buy one with white neutral wire so it will work with your application.
Jun 10, 2013 | Leviton R01-PR180-1LI Decora 180 Degree...
Replacing older t86 two wire thermostataà
brown goes to live black to nutral green to earth
Nov 14, 2009 | RTO Home Heating Products 5.5HH240...
My son took the old thermostat off the wall and didnt mark the wires. I have a new CT87K4446. The wires I have coming out of the wall are red green and white. On the new thermostat I have R W Y screw downs...
Usually when you have the Y terminal on the thermostat (that would be cooling terminal), there should be 4 screws to connect to. They would be R- to transformer, W- to furnace or heat, Y- to outdoor air conditioner and G- to furnace blower.
You might go to the furnace to see where these wires go, they should have the same terminals on the furnace except for cooling, it usually connects to the outdoor unit wire directly.
Oct 12, 2009 | Heating & Cooling
I took out an old cooktop which only has the black, white and ground wires. The jennair cooktop with 5 electric elements has black, red, white and ground. how do i connect these together.
sounds like the old one is 110 volts , and the new one is 220 volts. incompatable, as the 220 ones would work, but at half power if you didnt use the red wire. might work fine. omit the red wire and wee what happens
Jun 14, 2009 | Jenn-Air JEC9530 Electric Cooktop
How to install rear hatch door struts on a 97Astrovan
in case you havent figured it out, or for the next person that needs help. . .
i needed to replace my rear window struts.
i stuck a flathead screw driver in each of the metal clips at each end of the strut and pryed them loose. the struts popped right off the mounts. i also unscrewed the rear speaker panel so i could remove the wire connecting the strut to the car (rear defroster?) and remove completely. i wanted to take the whole unit to the autoparts store and compare it to the new strut. when buying replacements, i noticed the new struts did not come with the electrical housing on the upper end, just a male thread. i was stumped because i couldnt get the housing off of the old strut . . .i didnt want to damage it trying.
i finally i got the nerve. all it took was a pair of channel locks (pliers). grip the rod tight enough to unscrew the housing from the rod. after breaking loose, it should come right off easily.
i realized after that i didnt need to open the speaker panel and disconnect the wire. i probably could have just unhooked the strut and unscrewed the housing (while the wire remained connected to the van), screwed the new strut back into the housing, and reattached the strut to the van.
installation is the opposite of removal. i also read on a few sites that its a good idea to replace them both at the same time.
May 21, 2008 | 1997 Chevrolet Astro
Computers & Internet Logo
83 people viewed this question
Top Galaxy Computers & Internet Experts
Paul Chapman
Paul Chapman
Indermani Tiwari
Rod Amo
Rod Amo
Level 1 Expert
Are you a Galaxy Computer and Internet Expert? Answer questions, earn points and help others
