Question about Toshiba Televison & Video
Remote control tv of model tw65g80 is not working
What is the tv code for sylvania model #SST4324
1. Your TV has a high failure rate with the IR module. When this goes bad no remote will work with your TV. If you still have your OEM remote try testing it to see if it is transmitting a signal. Instructions below.
2. Many universal will not work your model TV. I suggest getting an OEM remote. You ca purchase from link below. SYLVANIA NE139UD TV Remote Control How To Test My Remote Control ReplacementRemotes com
Jul 09, 2014 | Philips Magnavox Learning Universal Remote
Toshiba TV 65" TW65G80
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 22, 2012 | Toshiba TW65G80 TV
Projection lights are shining through screen
remove back cover ck mirror assembly. prob broke loose during move;
Dec 06, 2008 | Toshiba TW65G80 TV
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Conia tv remote codes
I have a Conia LCD TV and the remote died, I purchsed a universal remote and without the codes even on search modes could not get it to find the t.v. I found theat DJ Electronics sell replacement Conia TV remotes online. So if you just need areplcement remote, know your TV model number and you can just replce your old remote.
Jan 21, 2008 | Televison & Video
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
REMOTE CONTROL CODE FOR HAIER TV
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
Dec 09, 2007 | One For All URC-4330 Remote Control
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
