Question about SimpleTech Pininfarina 60GB External USB 2.0 - Grey SP-UE25/60 (SPUE2560) Hard Drive
XP won't recognize Simpletech Pininfarina 60 GB external hard dr
I've had this external hard drive for a few years but haven't tried to set it up until today. I've lost software that apparently came with it. My Windows XP doesn't open or run it. Do I need to find a driver? Can I find one free or must I buy another copy of what I once had? How do I go about finding the proper driver, if that's indeed what I need. Red and blue lights seem responsive on the hard drive model number SP U25/60
Thanks for your help.
  • 788 Answers
Make sure you are plugged into a USB2 port and not a low speed port.
You can Bing the device name and more than likely find the drivers at the origanial manf.
Try removing all other external devices before installing the new one.
Re-boot the unit with all disconnected.
After the until has setteled down, plug in your USB drive in the USB2 Port and see if the operating system see's the new installation.
If it is see correctly, then you can install your other devices.
Hope this helps you.
P.S. you may want to look at the jumper setting on the USB drive and set them to default.
Posted on Oct 01, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
Changed internal harddrive and now, computer cannot recognize the simpletech pininfarina external hard drive
If you loaded a driver for the Ext HDD with the old HDD, simply reload it or download off the net.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
My SimpleTech 320GB external hard drive is no longer recognized
trying using it on another system and and see if it happens like that. if it does, you may want to get a driver for the hard drive. it is likely the driver is corrupted. try it on another port also.
Jun 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
Simpletech hard drive
Your desktop usb compatibility is not supported your 160GB. The only way to attach you 160GB is to make it secondary partition to your primary drive by opening the CPU and attach it to your IDE cable.
Don't force yourself if you cannot do it by yourself just leave it to the expert. Probable cause to damage your hard drive if it is not installed properly.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 29, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Computers & Internet Logo
450 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
