Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Seagate Ultra ATA HDD
New Drive. While formating, interuppted by me. Now shows disc error & computer keeps re-booting without opening Windows.
    Welcome Back:
    Visited the website for 2 consecutive days.
You can use partition softwares such as PQmagic to solve this problem
Posted on Dec 24, 2007
Cannot boot from Momentus Ultra ATA 160 GN HDD
it can only clone the windows files and folders there is other files located on a hidden system on the hard drive, when you install and new hard drive these file are fixed to the drive. to make a bootable drive you need to install these files from a windows disc then add clone files over the top so these files don't get deleted.
May 27, 2017 | Seagate Momentus 5400.3 Hard Drive
Seagate hard drive moved from one computer to another won`t boot
Now this is just my opinion but i tried to do the same thing one time and it would not work so I was left with one choice. Do a fresh install, I bought a second hdd and did a fresh install then plugged my original hdd in as a secondary so I could still access my old files.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 12, 2018 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate satat error
the firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
FAT to NTFS without Format
Use the following link to repair the windows file system if you have the windows xp cd
http://pcsupport.about.com/od/fixtheproblem/ht/ntldrntdetect.htm
Thanks
Proton
Dec 26, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
SEAGATE HARD DISK DRIVE PROBLEM...
just remove the jumper settings of the HDD like this one.;
choose the master without a jumper.
let me know
Oct 04, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
You don' t say what OS or even type of computer (PC, Mac, Windows XP, 98, vista etc) you are running, or whether the drive has been used before. If it's a new drive then it probably needs formatting, so you can allow the OS to do that. If it contains data that you need then DO NOT allow the OS to format it.
If you know it is formatted & contains data, then it sounds like the OS is not recognising the format. Windows 98 typically won't recognise NTFS disks formatted on Windows XP for example or Linux Ext3/4 format disks won't be recognised by Windows. In the latter case, you can download a free driver which will do that for you - google Ext 4 and Windows.
Aug 26, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
