Question about Emerson EWF2703 27" TV
Remote won't work - channel stuck at Video2 - Emerson EWF2703 27" TV
  • 448 Answers
Remove the battery from the remote then press each button twice.
Insert new batteries then check the operation of the Remote control.
To troubleshoot the video 2 issue, connect different video source to the TV then select the connected video input.
If the issue persists then try resetting the TV to the original factory settings.
good luck!!!!!!!!!!!!
Posted on Oct 01, 2009
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
How do i get ot the aux channel?
Try changes the input on your TV. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc.
Jul 01, 2011 | Televison & Video
I can not get the chanell to change on my Orion 27"2002 T.V. I can only change chanell from Video/ch4 and video2. I have Oneforall remote as also Jensen surf series. Can not find remote codes for...
Hello, I haven't found the codes for either remote. I did manage to find the menu after combining the volume buttons together. I have got the channel's to work by going to the menu and adding the channel's.
Apr 17, 2009 | Televison & Video
Universal remotes
You have to use the input selection button. Example like video, video1 video2, aux etc...
Sep 01, 2007 | Symphonic ST419E TV
Emerson EWF2703 27" TV Logo
280 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
