Question about Rowenta Commercial Garment Steamer - White
Does it require salt? - Rowenta Commercial Garment Steamer - White
    President:
  • 2,976 Answers
NO. Salt will cause deposits in the system. Only use the chemicals that the manufacturer recommends.
Posted on Oct 01, 2009
Testimonial: "Very quick response with exact information. Many thanks."
Does it need to add salt to make it work?
irons only use distilled or deionized water
while may people use tap water there are minerals in the water that will eventually cause corrosion and leave black marks on the clothes being ironed
Sep 01, 2015 | Irons
Why is my rowenta iron having something white coming out of it?
Do not use water softened by salt. It\'s all the salt coming out of your iron from the water you are using. Use bottled "Spring Water" do not use "Distilled Water". Your iron will spit and pop.
Jun 06, 2014 | Rowenta Irons
Rowenta Focus iron has only been used about 5 times. I use bottle water and iron spits out rust colored residue during steam cycle.
If you mean bottled drinking water, that is full of mineral salts, no good. Use demineralised or distilled water from the supermarket, it is cheap.
Clean the iron first like this
http://wiki.answers.com/Q/How_can_you_clean_rust_in_a_steam_iron
Aug 27, 2013 | Rowenta Irons
I have a bosch B25l steam generator iron, it will not steam
Try a quarter teaspoon salt added to the water. Switch on and let it steam through. Do this Just once.
Apr 08, 2013 | Irons
How do you run clean cycle - I have lost the manual
Self-Cleaning and Maintaining Sole Plate
Use the self-cleaning feature once a month by moving the steam lever back and forth from the "dry" setting several times. This will remove any residue from the steam valve and ensure that the steam system works properly.
Wipe the sole plate with a soft, damp cloth while the iron is cool and unplugged.
Run the iron over a cotton cloth several times to remove any residue from the sole plate.
Cleaning Anti-Calcium Feature
Fill the water cup that came with your iron. Use enough water to reach the Sunbeam logo in the top corner of the cup.
Add a teaspoon of salt to the cup and stir.
Empty the salt solution into the water reservoir in your iron.
Allow the iron to stand for 15 minutes, then empty out the water reservoir.Repeat this cycle with a second cupful of salt water.
Rinse out the reservoir with clean water. You should perform this cleaning once a month.
Jul 28, 2011 | Sunbeam Irons
My rowewnta steamer is not producing steam and I have lost the manual
if u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
May 25, 2011 | Rowenta Commercial Garment Steamer - White
I have a turbosteam 6060 sunbeam iron. It will not steam, just beeps and cycles off
If I was you I would either go to the Sunbeam site and in the search box enter the model name and number and get a download a manual for fixing the iron or troubleshooting problems. If that don't work Send the Iron back to the company for a new one.
Feb 11, 2011 | Sunbeam 3017 Iron with Auto Shutoff
Emson light weight iron on the handle says turro ''the iron that steams'' handle has measures of salt 2 add 2oz of water was moms but can not find how to use. can you tell me direction on where to find...
Remove the handle on the iron. Then fill the opening with two measures of table salt, using the handle's device to measure the salt. Add 2 oz. of water in the opening, then reattach the handle. Connect the handle and plug into an outlet. After a few seconds, the iron should begin steaming. It is then ready to use.
Apr 26, 2010 | Irons
Holes clogged with plastic
I would put the un-plugged iron in to the freezer so as to get the plastic as rigid as possible and then try to extract all of the plastic from the steam holes.
As far as cleaning the irons surface.
Step1 Place about a teaspoon of salt on a paper or cotton towel and run the iron over it on the high setting gently with the steam off. This will cause the dirt to stick to the salt and will wipe away easily. Step2 Rub the iron across newspapers to remove a waxy build up on the surface. Use the high setting with the steam off. Step3 Apply ammonia to a rag and use it to wipe the surface of the iron to remove oil. Use a separate cloth that is wet with water to rinse it off. Make sure the iron is turned off. Step4 Combine equal parts vinegar and baking soda and scrub the surface of the iron with it. Use a separate clean cloth to wipe away any residue. Step5 Heat in a saucepan a cup of vinegar and sprinkle in about a teaspoon of salt. Heat the mixture until the salt is dissolved. Use this to clean the iron's surface with a clean cloth. Use a second cloth to wipe away any residue.
Good luck
Aduz
Mar 22, 2009 | Tefal Ultraglide 1549 Iron
Rowenta Commercial Garment Steamer - White Logo
122 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
