Question about Hoshizaki KML-451M Low-Profile Crescent Ice Cuber
I have hoshizaki kml 450 mah and i need water pump for it can you give me the part number . old onr is burnt out
  • Hoshizaki Master
  • 1,250 Answers
Http://www.hoshizakiamerica.com/manuals/KML-450M_FandH_pts.pdf
this will take you to the Hoshi web site and this is the parts breakdown..
Hope this helps.
Posted on May 02, 2010
  • 122 Answers
I can get that pump. Look us up on the repair directory under refrigerators zip code 60060
Northeast Cooling LLC :)
Posted on Oct 01, 2009
Its a 450 mah hoshizaki, it keeps jumping from freeze cycle to harvest cycle without giving it enough time to make a load of ice
usually, if it does not stay in the freeze cycle long enough to make ice or it just makes slivers of ice, it is loosing water. during the freeze cycle, look to see if water is draining down the drain from the machine. If not, I would look at the float position. it should be almost completely in the lower, down position. give that a shot.
May 31, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
Kml 250mah
some over flowing is ok as long as it does not go into the ice bin. if it is, the drain in the res is restricted some how, or the pump is not pumping the water out. start with that and let me know
May 22, 2014 | Hoshizaki Kitchen Appliances - Others
Kml 600 mah manual
go to http://www.hoshizakiamerica.com/. Look for your manual by clicking on "Support" and then fill in the model of your unit and then click "get manual". and you are there.
Feb 17, 2013 | Hoshizaki KML-600M Low-Profile Crescent...
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Hoshizaki KML-451M Low-Profile Crescent Ice Cuber Logo
316 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
