Question about SanDisk Sansa m250 MP3 Player
Powering on my player does not starts after i formatted it.
    Genius:
  • 1,027 Answers
Http://www.sandisk.com/Retail/Default.aspx?CatID=1532
download the sansa connect recovery tool and manual
load the recovery tool on a pc hook the mp3 to usb cable and pc and run the program.
Posted on Mar 06, 2008
How do you reset a Mp3 player with 512 mb but it doesnt have a reset button?
To reset your Sansa Mp3 player. 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes.
You can also format using Media Player if you have unfrozen your player. 1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) .
1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that...
Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Sep 17, 2010 | Audio Players & Recorders
Tip
Sansa Mp3 player frozen? How to reset and format if needed.
To reset your Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch.3. To turn the player on, slide the Power switch up then release instantly.
You will lose all your music - sorry. Also try: 1. From the Main Menu, in the player -> select Settings -> Format.2. Select Yes.
You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the player to the PC in MTP (See next step to change to MTP mode) .
on Jan 24, 2010 | Audio Players & Recorders
Will not turn on
To reset your Sansa Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present. You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes. You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) . 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that... Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Apr 16, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa clip is frozen how do i reset
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using media player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu, Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
My Mp3 player is frozen on a file it says it's chargeing when its not
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa m250 MP3 Player
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
Corrupt playlists
Connect the player to the power supply and PC.
Press and hold [Vol +] & [POWER] until player resets.
As soon as the screen goes blank, release [Vol +] & [POWER] and press and hold [Vol -].
Player should show the connection screen, but without the status line at the top
PC will recognise the player as a removable drive.
Once the PC says that the device is ready to use, open My Computer and player should be in the list. (GoGear)
Right click on the player and select format.
Tick the "Quick Format box" and make sure the format is FAT32, and click start.
When the player has formatted, safely remove, and power up. You will get an error message on the player saying "connect to PC".
Connect to PC normally and repair with Device Manager.
Feb 25, 2008 | Philips GoGear HDD6330 MP3 Player
Not powering ON..getting switched off Transcend T.sonic 610 MP3 PLayer
Do NOT format it -- I did a complete format as another user suggested and now it only appears to be useful as a pen drive. It will not play anything and I've tried reinstalling the firmware and it doesn't even recognize that it's an mp3 player so I can't install it!
Jun 28, 2007 | Transcend T.sonic 610 MP3 Player
Refresh Database
Format the player using the formating tools given in the disc-yr problem will be solved
Mar 08, 2007 | SanDisk Sansa e250 MP3 Player
Transcend T.sonic 610 MP3 Player 2 GB
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Jan 28, 2007 | Transcend T.sonic 610 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
