Question about Sony Cyber-shot DSC-H9 Digital Camera
Camera doesn't stay on- shut down in a few sec
Camera was droped. The plastic piece inside of the shoot button was broken. My husband opened the body of the camera to check, what happened to the button, after that anytime I turn my camera on - it stays on for a few sec and then turnes off
  • 11,896 Answers
This is actually a common problem that requires the firmware to be updated. Kind of like software and hardware in one. The manufacture will do it for $50 or you may be lucky enough to find a download on the web.
Posted on Oct 01, 2009
Can't open back door, pull latch but door doesn"t open.
the inside handle is broken remove the door card from inside truck and manually open the latch then inspect you will probably find the plastic piece is broken and will need new handle
May 06, 2014 | 2003 Ford Expedition
Rear tail gate light stays on
I hope this is an easy fix, but I doubt it!
Try to locate the switch, it should be a push button, that opens when you lift the rear gate, and closes when you close the rear gate.
If that switch is broken, it will stay on.
Also, the switch, usually made of plastic, could have fallen down inside the hole where it mounts, also causing it to stay on.
Perhaps it need adjustment to turn off the light.
If the lift gate has been sprung or is not exactly where it was when new, you might be able to adjust it somehow to work.
Like if the gate does not come close enough, you might glue or screw a piece of metal on to the contact surface to make it turn off the light.
My sad suspicion is, put a piece of tape over the light!
That is what I have had to do in a few cases.
Be blessed.
Mar 01, 2013 | 1991 Toyota Previa
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
The stem pulled completely out of my watch.It doesn't have a screw set for holding stem/crown in watch.Is it just a plastic piece that holds it?Thats what thereal cheap quartz mvmts have.Some you just...
push it inside while you were turning it until you feel something in inside locks, but if not effective, yur watch must be opened to pus the lock inside while you are inserting the stem. if still not effective, your watch module has to be replaced by a new one. i hope this thing will helped you a lot.
Sep 12, 2011 | Citizen Watches
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
How to replace cr2016 from 450d/XSi or 500D/Xt1
The other bloke doesn't know what he is talking about..this is plainly obvious.
Looks like the CR2016 is inside the battery compartment under a small cut-out plastic piece (on same side as hinge). Use a torch and you can see it under this plastic piece.
You either need to dissemble it to get access or break off this plastic cover to replace...or take it to canon.
Dec 22, 2009 | Canon EOS 450D / Digital Rebel XSi Body...
S2000hd batter door. One of the little plaastic "clips" on the canera body that the battery door latches into has broken and the door does not stay closed the way it should. Fuji tells me no warranty, body...
Get a piece of flat aluminium or steel approx 2 inches long, drill a hole at one end and use the Tripod socket to hold the flat steel down, over the batery lid to hold it shut.
Jun 22, 2009 | Fuji FinePix S2000hd Digital Camera
"Open" written on screen
There is supposed to be a little plastic piece that pushes down a button that tels it that it that the door is closed that plastic piece is broken off. Look for it and glue a little piece of plastic on it, should fix it.
Jun 04, 2008 | Toshiba SD-P1600 Portable DVD Player
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
Apr 05, 2008 | Olympus Stylus Verve S / ?-181 mini S...
Sony Cyber-shot  DSC-H9 Digital Camera Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
