Question about Nokia 3110 Cellular Phone
SIM CARD REJECTED
I found security code and i started pressing some numbers and it is my last chance then also i pressed some number then the messag came
SIM CARD REJECTED
    President:
  • 1,462 Answers
Actually its not security code..Its SIM PIN NUMBER..
PIN CODE is SIM dependent and not phone dependent
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
Now since the SIM is rejected, you have buy new SIM requesting that your SIM is rejected from the operator
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Posted on Oct 01, 2009
    Sergeant:
  • 138 Answers
Just call your service provider and tell them you need the PUK code they will ask for the number off the sim card and will provide you with the unlock code for free.
How to get security code of asaha 303
Dial using the keypad: * # 0000 # - the version number displayed on the display.
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
*#7328748263373738# resets security code.
Default security code is 12345
SIM Clock
Stop allowed
Warranty Codes
* # 92702689 # [* # war0anty #]
Dec 29, 2014 | Cell Phones
Tip
Nokia codes +++++++
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#67705646# This will clear the LCD display(operator logo).
*#2820# Bluetooth device address.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
on Sep 05, 2009 | Nokia 6300 Cellular Phone
Insert sim card 5320
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Nokia shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Nokia 5320. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Jul 24, 2013 | RIM Cell Phones
I set a security code on y Nokia 2700 classic but the set not accepting that code now what should i do now and also please tell me that where should i enter the master code my cell's imei number is...
thanks buddy to give me question. your question answer under here. just follow the instructions.
may be you know that nokia default code is 12345. first you can try these no. but if you change the security code then there are two way to crack the no.
first one is use the master code appropriately. i am tell you this is 50/50 chance. it may be or not.
and the last and final way is using flash box and make default your security code.
but this time i am giving you master code.
On the main screen type in:
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
Apr 04, 2011 | Nokia Classic 2700 Cell Phone
Puk code
How to find PUK code number of SIM Card (mobile phone). Many people use PIN number for their phone to lock some of the stuff or features.But if you enter PIN number 3 times wrong then your SIM card is blocked and will ask PUK If you enter PUK code number 10 times wrongly then your SIM card will be rejected and you have to buy a new duplicate SIM for your mobile phone. Here are the steps to get PUK number for different networks -
Airtel:
create a new message from any Airtel number (of your friends or relatives), type PUK PhoneNumber and then send it to 121 (toll free number)
For all other networks:
Call to your customer care number from other SIM card of same network and tell your details to them. They will first verify that you are the owner of that SIM, so they may ask name as registered on form, last call number, billing address, email ID, numbers you recently called, numbers you recently messaged or any other personal details. So keep all these ready when you call, then they will provide a PUK number, enter it and your mobile will be unblocked
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 14, 2011 | Computers & Internet
If i keep presseing random numbers for the PUK code and get the sim card locked and rejected how do i get it unlocked or unrejected?
You should call your service provider for the PUK code.
If you enter the code 10 times incorrectly, the sim card becomes unusable.
You will have to purchase a new sim card.
Jan 09, 2011 | Cell Phones
When i put my sim in it asks for an unlock code?
It is asking for code because you change your sim card security when you insert this in phone last time. It is asking for PIN code. Only network service provider know this code, contact customer care of your service provider. If you entered wrong PIN number three times your sim card will be rejected hence don't try to enter wrong code.
Feb 07, 2010 | Lands Phones
My Nokia n 72 says sim card rejected
you need to replace your SIM card now the PUK is a PERSONAL UNLOCK KEY code that changes on a daily basis and if you dont call the provider for this and enter the wrong code too many times it "burns" the sim (security feature)
Jun 27, 2009 | Nokia Unlock N70 N71 N72 N90 6630 6680...
Sim card rejected
You need to do some testing first.
Put your sim card on another phone (should be unlocked or the same provider) and see it it works.
Put another sim card on your phone (should be the same provider sim) and see if it works.
From there you can check where the problem lies.
Apr 09, 2008 | Nokia 2610 Cellular Phone
Puk code
The PUK (Personal Unblocking Key) is available at your service provider. Some sort of Identity will be needed.
Nov 06, 2007 | Nokia 6030 Cellular Phone
Nokia 3110 Cellular Phone Logo
369 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
