Question about Dryers
I have an similar problem with my Amana Dryer LEA30AW.
A few months ago it quit heating up. A friend checked the heating element, and the coil was broken, so we replaced it. Worked fine for a couple of months,then quit heating up again. Another friend found that one of the thermal fuses was not working correctly, so replaced that. It worked for a couple of days, and now, AGAIN, it is not heating up. We checked the element which appears to be fine, and all the other fuses. I'm guessing something, somewhere, is causing it to overheat, and so it is shutting down in order to prevent overheating??? Just had new venting(code/energy efficient) put in a few months ago, too, and all the lint has been cleaned out. HELP! I'm a single mom who really can't afford a new dryer, and this one is only about 5 years old. What's the next step?
  • lthorssen Oct 01, 2009
    Vent tubing is new and clean. It doesn't heat up at all, so can't run it on low heat. Filter is clean and has been very much so ever since we replaced the original heating element. Any other ideas?
    Genius:
  • 1,474 Answers
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Posted on Oct 01, 2009
  • Gerry Harvey
    Gerry Harvey Oct 01, 2009
    Sorry to add, Check hose is free passing air and not kinked...
  • Gerry Harvey
    Hi,If drier is not heating It would be cut out @ back, Element/ or thermostat, You would require a multimeter to check Element and stats, Apart from a broken wire which i dont think it is its nomally the heating Element, Im sorry that you replaced it before but you should have some warranty on the part. Good luck..
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
On the amana LEA30aw which wires go where on the heating element?
There is usually a schematic pasted to the inside service area unless it fell out. Read it & start tracing wires. The power to the element should pass through a fuse, a thermistor(cycles power on and off relative to heat and a safety switch that kills power if it gets too hot. Don't take short cuts.
May 14, 2015 | Amana Dryers
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
I need to know what is the correct wireing for a amana dryer element model LEA30AW
There are two wires that run into the element. You cant mess it up if you have the right two wires. What wires do you have and the colors. Can they reach the element connectors. How many do you have?
Jul 27, 2011 | Dryers
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
I just bought a used Amana Dryer LEA30aw and when I turn it on it has a slight burnt smell. What could this be?
At some point it was run without a filter or had a hole in the filter what your smelling is probally lint that has stuck to the heating element. It should go away after about 3 or 4 uses. If it gets worse I would have it checked but on a used dryer this is a common occurance.
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Office Equipment & Supplies
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Dryers Logo
284 people viewed this question
Top Dryers Experts
